My 2wd wasn't hard at all to remove the tranny. The main problem I had was the cross-member. The top bolts are hard to get to to remove the "dog ears" where the rear motor mount is located.
I don't know how much harder it would be with a transfer case for the 4wd. The only thing I suggest is a tranny jack. Those things are priceless when removing and installing a tranny.
If you do do it yourself, just put the front on stands and use a second jack to support the motor so you don't push the fan into the radiator.
If you don't remove the tranny completly then it would be easier yet. Just get it pulled backwards enough to access the torque converter. If your doing the motor seals your self then that's a different ball of wax. You'll have to get the motor jacked up 6 inches or so to get the oil pan droped if you have to. Go to autozone.com they have the repair guides listed on-line, comes in real handy.
Good Luck, keep us posted.
THE BLUE BOMBER!
87 ford f-350 cab-chassis dually. 2wd, 6.9, 3 speed C-6. 3 leaf helper springs, 11,000 gvwr, pintle/ball hitch, 6 pin round trailer connector (unhooked currently). Rear generic truck stop lights. Twin I beam front end with coil springs. Plow lights and switch to go from headlights to plow lights. 8.5 foot meyer diamond plow with central hydrolics. 8 foot rugby dump bed. 167,000 miles and still strong.
