Check valve - Diesel Forum - TheDieselStop.com
Old 02-09-2010, 10:21 AM   #1 (permalink)
Check valve
ive got an 87 and it loses prime once in a while. Is there a check valve after the return lines on the pump or somewheres in the system. My thoughts are that it could be sticking open then sucking air from the tank. I also have a leaky injector line which i just ordered a new line to replace. Thanks for any help.
ammfarmer is offline
Old 02-09-2010, 10:36 AM   #2 (permalink)
Joe Mc's Avatar
My Photos: (39)
How do your return lines look? Clean and dry or damp? Damp return lines are often the problem.
Do you have all the clamps on your injector lines? I think there should be 4 of them, the lines will crack without the clamps supporting them.
Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW
BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
Triple A-pillar pod: Isspro EV voltage and oil-pressure gauges.
Road-Watch System (Air and road-surface temperature gauge).
Chicken Lights Gone.
Joe Mc is offline
Old 02-10-2010, 06:57 AM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (109)
If you mean the steel line, if the leak is above/below the plastic cap that would usually be the orings........ above the cap nut is usually the line, resetting the line alignment and retorquing the cap nut... sometimes seals them off. As stated all the steel line vibration clamps (4) MUST be installed in the correct locations or line cracking/vibration wear is a given.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 02-13-2010, 02:51 AM   #4 (permalink)
magusjinx's Avatar
If there is a leak where fuel is getting out then that is a fair target for air to be getting in ...
magusjinx is offline
