Tach signal is generated by the sensor located in the top front of the engine. It sits just to the right if you are standing in front of the truck. It is mounted in the gear cover and will have two wires attached to it. As far as tapping into it for cruise, I don't know... mine has factory cruise. I am sure someone will answer that part.
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually,
1997 Jayco fifth wheel 323 RKS, Robins 16K dual axis hitch
Apillar pod with: Autometer C2 Series gauges: pyro,trans, boost
Hypermax Cowl induction, Flex-A-Lite 26K tranny cooler w/fan
K&N air filter (we'll see in a million miles)
Tekonsha "prodigy" brake control
Train Horns: Pictures here
