drum groove - Diesel Forum - TheDieselStop.com
Old 11-17-2012, 06:37 PM   #1 (permalink)
drum groove
i was changing the shoes on my truck and noticed far inside the drum is a pretty nice little groove carved in it and i was just wondering if i need new drums or will it be ok i dont need much stopping power. the groove is very small but a little deep should i be ok? i never stomp on my brakes im pretty easy on them.
1987 6.9L N/A xlt lariat 4x2 c6 3.55
IDIcagle is offline   Reply With Quote
Old 11-17-2012, 06:47 PM   #2 (permalink)
chuckster57's Avatar
If there is a groove in the surface that the shoes touch, I would turn/replace the drums. Are you going to be okay for a while, maybe yes, maybe no. You can't plan for panic stops caused by the other guy.
Sent from my iPhone using AutoGuide.com App
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now   Reply With Quote
Old 11-18-2012, 10:10 AM   #3 (permalink)
My Photos: (27)
It's most always embossed on the outside of the drum the max allowable diameter after turning (determined with a drum caliper). If it's just one narrow groove I wouldn't worry about it.
LMJD is offline   Reply With Quote
Old 11-18-2012, 10:20 AM   #4 (permalink)
Have to look again, I don't remember seeing anything like that. I did have to replace D/S drum and wheel cylinder when I bought the truck. But that was 4+ years and thousands of cars ago.
Old 11-20-2012, 09:53 AM   #5 (permalink)
My Photos: (27)
Seems to me I was told it is a federal law. At the last shop I worked at and one years previous we had a complete brake setup------ brake drum lathe, shoe arching machine, and rivet remover and rivet press for everything from air brake drums/shoes down to pickups. Everything always had the max drum I.D. stamped on the drums. With that said, other than air brakes (no bleeding, etc), I always hated doing brake jobs.
Old 11-20-2012, 09:56 AM   #6 (permalink)
Max I.D. And min O.D. (Rotors) have been stamped in for years like you say. I just don't ever remember seeing any kind of groove machined in the drums.
Old 11-20-2012, 10:33 AM   #7 (permalink)
My Photos: (27)
Wow, total misunderstanding, and I thought we shared the same brain (scary as it is)! Sorry, thought you were referring to the max I.D. stamping.
Old 11-20-2012, 10:37 AM   #8 (permalink)
...I thought we were talking about the groove in the first post. We do share the same brain only this time the right half didn't know what the left half was thinking
