Dumb Move, Gasoline in Diesel. - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 10-27-2005, 12:28 PM Thread Starter
My Photos: (44)
Hey Men;
I have been filling up my wife's car, so today I was getting some fuel in my F250 6.9 and I put in 3 gallons of regular gasoline in my front tank before I woke up, do you think it will be OK to fill the rest of the way with diesel and use it up or should I try to syphon it out, it was right down to empty when I put the gas in it.
Thanks, Bill Miller.
1995 F250 XLT Powerstroke, Supercab, E40D tranny, 3.55 limited slip diff. (with all the bells and whistles) bucket seats and console, electric windows and door locks,intermitnent wipers, tilt wheel, cruse control, overdrive and turbo my IDI has none of these.
1985 Ford F-250 6.9L Std.cab,C-6 tranny, 3.55 Diff. DEEZEE Running boards, added factory Tach with existing circuit board, heater water bypass valve.
dreamachinef250 is offline
post #2 of 13 (permalink) Old 10-27-2005, 12:53 PM
ThreeStarJR's Avatar
Re: Dumb Move, Gasoline in Diesel.
Oooops! Bill don't think that filling it on up would be safe. Even if the tank was completly empty before the gas, you would still have over 25% gas in there. Try to get as much out as you can, can't say for sure, but if you got it down to 1/2 gallon or less and then filled it with fuel you may be safe.....Hang loose before you do anything, someone who has been there done that will fill us in. good to hear from the Memphis flash! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Jim
529/1220
10 17 08
BDP "DOMINATOR 66,"
BDP/Casserly's stage 3 HI-BIRDS
BDP Fuel system
Hypermax rods
Caltracs
96 F-350 CC, XLT, drw, 2wd,...
#3
ThreeStarJR is offline
post #3 of 13 (permalink) Old 10-27-2005, 01:40 PM
I did the same thing on my old 1987 Ford diesel. I filled the other tank with diesel and drove to a shop where someone syphoned (by mouth [img]/ubbthreads/images/graemlins/vomit.gif[/img] ) the gas out. I simply refilled it with diesel and had no problems. I would definitely drain as much as possible.
'97 F350, Crew cab, 4x4, 120,000 miles, 4" dp straight through to tail pipe, rhino liner, backup lights, Tymar intake.
pchtxag is offline
post #4 of 13 (permalink) Old 10-27-2005, 02:04 PM
Get it out, that much is likley to harm your injection pump!
Rick H...
Pres Omaha Metro PSD Club
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
RickHredf250 is offline
post #5 of 13 (permalink) Old 10-27-2005, 05:39 PM
My Photos: (5)
Bill,
3 gallons - no worries. Just fill with diesel and throw some lube at her (Stanadyne or something to that effect) heck if ya got a quart of motor oil hanging out throw that in as well then enjoy. She'll do just fine. Diana that showed up at the 04 IDI Weekend in Michigan did the same thing as you and she was fine. You might notice some complaining out of that tank but she'll do just fine. These diesels will burn about anything and once you dilute the gas down enough it will burn just fine - might be down on power but you got your other rig for that [img]/ubbthreads/images/graemlins/wink.gif[/img]
Travis
Will Work For Diesel Fuel.
argve is offline
post #6 of 13 (permalink) Old 10-27-2005, 07:27 PM
towcat's Avatar
bill-
the official MBZ owner's manual back in '79 encouraged the use of gasoline of no more than 12% of total volume to keep the diesel from gelling in the colder climates. 3gal in a 15gal tank is borderline ok.
86 f250 6.9IDI, 4spd 4X4 "the runt"
89 f450 rollback carrier 7.3IDI, ZF5, 4X2(in memory of...)
90 f450 conventional towtruck 60"CA 7.3IDI, E4OD, 4X2
92 f350 CC 7.3IDI, ATSturbo*intercooled*, ZF5, hydrostop, 4X2 "the nebuchadnezzar"
...Quack Quack................*P.A.K.*...
red pill or the blue pill? make your choice and pm me.
towcat is offline
post #7 of 13 (permalink) Old 10-27-2005, 08:32 PM
My Photos: (14)
Somebody check my math, but if there is 3 gallons in there and you have a 19 gallon tank, if you were to fill with diesel, you would only be at 16% or so. You could run it down some and continue to fill with diesel, then run it down some and fill with diesel. In actuality, if you filled it on up, added some additive, then ran out 5 gallons and refilled with diesel, you would be in right in there.
1987 F250 6.9 4X4 - T19 Trans, 4.10 Dana 60 Front/Ford 10.25 rear, Dual Rear Wheels, Carter P4594 electric fuel pump, Restrictive air filter opened up, Firewall repair kit installed, new clutch m/cyl and pedal bracket, bushings etc.,7.3 fuel filter conversion, Solid state controller OEM (new controller and Motorcraft GP's), Headlights converted to relay system with 65/100 Watt Cold Ice bulbs, Class V Hitch (10,000lb WC/15,000lb WD), Air Horns, Cadet 7' X 9' flat dump bed, 5 ton grainmaster dump hoist.
sle2115 is offline
post #8 of 13 (permalink) Old 10-27-2005, 09:40 PM
when i converted mu suburban to diesel the tank had 8 gallons of gas left. i was lazy and topped the tank off with diesel and everything was ok...
1987 f-350 crew srw long bed 7.3 N/A 4x4
2001 pontiac sunfire 2.2 <wifes>
dieselglory is offline
post #9 of 13 (permalink) Old 10-27-2005, 10:46 PM
cdnsarguy's Avatar
My Photos: (109)
Bill........I scored this info a while back. Your choice of course as to what you do.........
Mixing Gasoline with Diesel Fuel
At one time information was released suggesting that a small amount of gasoline mixed with diesel fuel for use in cold weather was an acceptable practice. This information was eventually retracted due to conditions that may result from such a mixture.
First and foremost is a safety factor. The gasoline fumes from gasoline are very rich and there is not enough oxygen available for a spark generated at the filler neck to ignite these fumes. The diesel fumes are too lean and will not ignite. A mixture in the right proportion could create fumes volatile enough to ignite from a spark generated at the filler neck.
Second, all injection pumps and injectors utilize the lubrication in diesel fuel to keep internal parts lubricated. Gasoline cuts down on this lubrication and can lead to premature injector and pump wear or even failure.
Although accidentally mixing a small percentage of gasoline with a tank of diesel fuel may not result in an immediate problem, it could still result in shorter pump and/or injector life. The only safe action would be to drain the mixture and start from scratch. While this may seem costly, it could save you from more costly repairs in the long run.
Pete
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #10 of 13 (permalink) Old 10-28-2005, 01:55 AM
Go ahead and fill it up with diesel. Three gallons isn't going to make a difference. I'd pour in a gallon of veggie oil or two cycle motor oil. I have seen this mistake made a lot of times, just most of the time people don't wake up and go to start their vehicle and it ends up dieing. A lot of people pour a little gas in with their diesel to winterize it. I have ran gas contaminated diesel before without any problems (guys put gas in diesel cans etc etc...)
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by
, Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
TimMiller is offline
post #11 of 13 (permalink) Old 10-28-2005, 11:38 AM
My Photos: (6)
I work with a dude that ran his 7.3 IDI home on mixed 2 cycle oil for the boat. Got low on fuel, late one evening, said "crap on it" and siphoned the boat dry.
hard to start cold the next morning, and smoked a little, but other than that... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
This same dude towed a house trailer with this truck, and another house trailer with D15 Allis Chalmers tractor. (like 42 hp) Had to steer the tractor with the rear brakes. That is to say, he ain't easy on stuff.
Never any problems out of his pump on this truck.
get you 3 bottles of 2 cycle oil, filler up w/ diesel, and let 'er rip.
cbuttre835 is offline
post #12 of 13 (permalink) Old 10-28-2005, 06:33 PM
IMHO, Is it worth the risk to fill with diesel and hope for the best? Seems like a mouth full of gas to siphon it out is alot better than having to replace fuel system parts or worse an engine.
'97 F350 4x4 Crewcab Powerstroke 5-Speed 4:10 LUK, HPX, Coolant Filter, Chipped, Warn Manual Hubs, SuperLift 4in
DaveSub is offline
post #13 of 13 (permalink) Old 10-28-2005, 07:33 PM Thread Starter
My Photos: (44)
HI Dave,
I think when I get around to doing it I will syphon out what I can. then fill with diesel and put in some Stanadyne treatment and drive off, I am operating on the other tank right now. Dave I was on Guam back in 1951-52 for two years, I was in the USAF and attached to Anderson Air Force Base there, I was out in the Boonies at a radio receiver sight, this was durung the Korean War.
I want to thank everyone for the comments and good info.
See'ya, Bill.
