early 6.9 injector pump problems... - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 08-05-2007, 06:49 PM Thread Starter
Hello all,
Does anybody know if there is a early 6.9 injection pump rebuild kit available?
If so, how hard is it to do the job?
All help is appreciated.
Only a sane man doubts his sanity...
This is what makes the crazy people so dangerous!
wi_saint is offline
post #2 of 5 (permalink) Old 08-05-2007, 10:43 PM
Re: early 6.9 injector pump problems...
Rebuilding an IP is a job for a pro. Those things are about 1000 times more complicated than a four barrel carb.
83 E-350 Club Wagon, C6, Red-neck WVO conversion.
kealan is offline
post #3 of 5 (permalink) Old 08-06-2007, 12:49 AM
Yes.. Nobody here will attempt to rebuild one. The clearances are less than 1/2 thousands and a flow meter bench is needed for recalibration. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
icanfixall is offline
post #4 of 5 (permalink) Old 08-06-2007, 01:21 PM
My Photos: (23)
Problem is, this is such a specialized device, that it truely requires specialized training and tools. For example, if your advance piston has the slightest slop in fit, it won't work. Rebuilders shine a light through the bore with the piston in it, and study it for many minutes trying to determine if the slightest bit of light is getting through. If it is, then the bore must be rebored and an oversized piston installed. This requires a lot of machining experience and precision equipment. I have a big Index brand 32" verical mill in my basement, and I know I would not be able to do this operation with the precision that is needed.
- Mel
1983 F-250HD 4X4
55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW
1987 Bronco
1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
agnem is offline
post #5 of 5 (permalink) Old 08-06-2007, 01:26 PM
Spencnaz's Avatar
My Photos: (14)
Believe us when we say, this is a job left to Superman or a professional in injector pumps.
You'll save alot of money and time just taking it to a good injection shop to have it rebuilt.
Seattle Injector here will rebuild a pump for the 6.9 for 500 bucks and turn it up a notch for you if you want.
The Green Monster
: 2001 F250 Powerstroke, 2WD, ZF6 transmission. Bully Dog GT Tuner set in tow mode. MotorSilk boric oxide added to engine, transmission and diff. Showing 30mpg on the freeway running home brew biodiesel. NTZ 1/2 Micron bypass oil filter. Dieselsite coolant filter. 4" open turbo back exhaust. Ford AIS intake. Donaldson ELF7405 oil filter. Caterpillar ELC next on the list.
Spencnaz is offline
