ENGINE CORE CHARGE - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 01-14-2006, 02:43 PM Thread Starter
ENGINE CORE CHARGE
I have seen many sources for rebuilt 6.9 engines and all have a price (with a rebuildable core).
None of the adds state what a rebuildable core is valued at, or what the price would be if a person had no rebuildable core.
Does anyone know what the rebuilders value their (not someone elses) engine cores at?? -- complete engine,heads,covers,pan,water pump,starter,etc.
1985 F-350
5.9 CUMMINS TURBO DIESEL
G360 GETRAG 5-sp
3:55 DANA 70
LongRider is offline
post #2 of 13 (permalink) Old 01-14-2006, 08:14 PM
My Photos: (14)
Re: ENGINE CORE CHARGE
Are you trying to find out what the value of a core motor is? Or are you thinking about buying a crate motor and don't have a core?
If you are wondering about value, I saw a 6.9 on ebay with a starting bid of $350 and it had two bids, neither of which made reserve. It was in Kalifornia though, so who knows what they are worth in the free world! [img]/ubbthreads/images/graemlins/smile.gif[/img] (just kidding) Oh, and the one on ebay didn't have injectors, injector pump, lines or any of the fuel system. If I thought I could get $350 out of mine, I would sell it. I have an 85 sitting in my barn from a scrapped F350! Actually, I have the transmission and transfer case as well.
1987 F250 6.9 4X4 - T19 Trans, 4.10 Dana 60 Front/Ford 10.25 rear, Dual Rear Wheels, Carter P4594 electric fuel pump, Restrictive air filter opened up, Firewall repair kit installed, new clutch m/cyl and pedal bracket, bushings etc.,7.3 fuel filter conversion, Solid state controller OEM (new controller and Motorcraft GP's), Headlights converted to relay system with 65/100 Watt Cold Ice bulbs, Class V Hitch (10,000lb WC/15,000lb WD), Air Horns, Cadet 7' X 9' flat dump bed, 5 ton grainmaster dump hoist.
sle2115 is offline
post #3 of 13 (permalink) Old 01-14-2006, 11:17 PM Thread Starter
Just like the question says, how much extra will the crate engine cost without a core to exchange??
1985 F-350
G360 GETRAG 5-sp
3:55 DANA 70
post #4 of 13 (permalink) Old 01-14-2006, 11:49 PM
Some re-builder qualify the term core, as in rebuildable core.
As in fully assembled engine (core), no basket cases.
Check their websites for explaination, as I have
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
BuilderBob is offline
post #5 of 13 (permalink) Old 01-15-2006, 01:23 AM
towcat's Avatar
you answered your own question. if you have no REBUILDABLE motor to turn in, you forefeit the core deposit.
86 f250 6.9IDI, 4spd 4X4 "the runt"
89 f450 rollback carrier 7.3IDI, ZF5, 4X2(in memory of...)
90 f450 conventional towtruck 60"CA 7.3IDI, E4OD, 4X2
92 f350 CC 7.3IDI, ATSturbo*intercooled*, ZF5, hydrostop, 4X2 "the nebuchadnezzar"
...Quack Quack................*P.A.K.*...
red pill or the blue pill? make your choice and pm me.
towcat is offline
post #6 of 13 (permalink) Old 01-15-2006, 07:35 AM
My Photos: (14)
Your original post doesn't say that exactly, but the only way to know what that core charge would be is to check with one of the many that sell them!
sle2115 is offline
post #7 of 13 (permalink) Old 01-15-2006, 07:38 AM
My Photos: (14)
I think he is asking what the $$ amount would be, but the way the question is worded, I was confused.
sle2115 is offline
post #8 of 13 (permalink) Old 01-15-2006, 07:42 AM
My Photos: (14)
From Jasper -
Pricing and Availability:
The Price Is: $3903.00
Core Deposit For This Unit Is: $500.00
Skid Deposit For This Unit Is: $100.00
Sold On An Exchange Basis w/Jasper Receiving Old Unit As A Core.
Jasper Engines and Transmissions Core Policy
General Policy:
ALL JASPER REMANUFACTURED UNITS have a core and skid charge billed at the time of sale. When the core is returned, a JASPER Associate will determine the amount to be credited back to the customerís account. The core returned must be a like-for-like Make, Model, and Type, but not a junkyard core. Cores must be returned drained of all fluids and oil, assembled and attached to the same undamaged skid or container your new unit was shipped in. Core must be returned within 30 days of the delivery date to receive credit. Full credit will be given unless certain damages & exceptions (listed below) are found.
Gas Engine Charges:
Overview: Like-for-like cores returned without visible holes or cracks in the block, not missing any parts, drained & bolted to the undamaged, supplied skid will receive full credit, otherwise, these charges will apply:
Crack/Welded, Hole in Block (50%) Missing Main Bearing Caps (15% each) Missing Pan (15%)
Missing Crankshaft (35%) Missing Rod or Rod Caps (5% each) Missing Camshaft (10%)
Missing Timing Cover (10%) 262/265/267/283/305/307/327 for 350 ($150) Missing Oil Pump (10%)
Missing Heads (25% each for V Config, 50% if Inline) Timing Components - Import Unit (10%)
Damaged Skid/Missing Skid/Not Secured to Skid (100% of skid charge) Core Not Drained ($50.00)
sle2115 is offline
post #9 of 13 (permalink) Old 01-15-2006, 04:21 PM Thread Starter
Thank you, that is what I needed to know, even if I can't speak English. Thanks.
1985 F-350
G360 GETRAG 5-sp
3:55 DANA 70
post #10 of 13 (permalink) Old 01-15-2006, 05:15 PM
My Photos: (14)
[img]/ubbthreads/images/graemlins/smile.gif[/img] no problem, I can't read English! [img]/ubbthreads/images/graemlins/smile.gif[/img]
sle2115 is offline
post #11 of 13 (permalink) Old 01-17-2006, 06:56 AM
Powerstrokedogg's Avatar
the core on my engine from my local salvage yard is $400
2001 F-350 7.3L 4X4(ESOF) CC LWB 4R100 4X4, WIX 46637 open element air filter, Wicked Wheel, walker BTM, 203* Tstat, IC tube foil removed, coolant filter, AIH removed, 08 aluminum finned rear end cover, DP tuner 80econ 140smoke high idle,Phantom gauges, ATS transmission,ATS deep trans pan, 5 star torque converter, V10 trans cooler, 4" MRBP SS downpipe, twin 4" stacks
1989 F-250 6.9L IDI E4OD 500,000+ miles(sold)
1982 VW rabbit 1.6L diesel
2007 Arctic cat 700 diesel ATV
1975 W900 Kenworth 500 Cummins
1997 Ford school bus 5.9 cummins
Powerstrokedogg is offline
post #12 of 13 (permalink) Old 01-17-2006, 05:28 PM
My Photos: (14)
Man, maybe I need to sell the extra one I got! Anyone need a motor! [img]/ubbthreads/images/graemlins/smile.gif[/img]
sle2115 is offline
post #13 of 13 (permalink) Old 01-18-2006, 11:44 PM
I do sle. if the company in Texas give us our money back for the bad one they sent us and we had to ship back. Do you think if you hot run test an engine the smoke created by oil cunsumption of roughly one gallon per five miles is noticable? it was noticable to us but i guess they are checked by blind people before they get shipped. they might send another one though. i have to find out before i start saying i can buy it off you. but i need to know it is a wrking motor or close enough to it to not cost me more than i payed for my truck. You can P.M. me if the details you want.
1986 F-250 Factory Ford blue and white paint, whith that darker blue line going down the side that is hardley noticable.
276,k miles 6.9 liter international havester enigine with dual tanks and rear wheel drive, maunual transmission push button glow plugs and inverter with master switch in dash, emergency strobe lights. Pretty plain factory truck. (burned out engine)
pg.photos.yahoo.com/ph/curinb_2000/album?.dir=3ecf
1986 F-350, rust red, 4 door cab, with full size bed. 6.9l international still running hard. 2300 peak inverter for good ac power one cross toolbox and two side tookboxes. All round work on anysite work truck.
curinb is offline
