ENGINE MOUNT QUESTION - Diesel Forum - TheDieselStop.com
Old 11-28-2005, 11:17 PM   #1 (permalink)
Are the rubber isolaters on a 460 Gas the same as the isolaters on a 6.9 Diesel or are they different??
1985 F-350, 6.9 4spd, Hypermax, 3.55 rears
BullHauler is offline
Old 11-29-2005, 11:28 AM   #2 (permalink)
Re: ENGINE MOUNT QUESTION
Part numbers are different, the 460 mounts have the same number for both sides, the 7.3 of the same year have 2 different numbers for each side, so my guess would be that there is something different. The way the mounts hook up to the frame are totally different, the 460 has towers bolted/riveted to the back side of the frame cross, the diesel mounts go through the oval of the cross, and have plates bolted onto the top of the cross.
86 F250 4wd, 6.9, T-19 trans, 4.10 axles, opened up the intake, fabbed 3.25 exhaust to self made muffler, 3.5 out to 4" tip. GM prefilter/water separator, Holley Red fuel pump.
92 F350 2wd crew cab, 5.9 Cummins with A518 auto, 4.10 axle, gear vendors overdrive.
fellro86 is offline
Old 11-29-2005, 07:09 PM   #3 (permalink)
Thank you.
