Engine stays running after i pull the key out and eventually stalls - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 10-20-2010, 11:49 AM Thread Starter
big99diesel's Avatar
any ideas sometimes it will shut off but most times i turn the key off pull it out and it will run for 15 sec after then die out
2003 F-250 6.0 74000miles Reg Cab 2wd.
big99diesel is offline
post #2 of 10 (permalink) Old 10-20-2010, 12:04 PM
86ford69's Avatar
I had a old f250 with a 302 that did that. I had a timing issue. Did you change the ip latley?
IRAQ WAR VET. 3 YRS SERVICE AND 18 MONTHS IN THE SAND. R.I.P ALL MY ARMY BROTHERS WHO DIDNT MAKE IT BACK. ROCK OF THE MARNE 3ID 3BD HHC 1 15th MECH INF. Old blue. 1986 F250 Xlt larait. Supercab long bed. 4x4 6.9 N/A. 4 speed with granny. No soup bowl. Sunpro 3 gauge pod for water, voltage and oil pressure. Push button glow plug control with Kenworth dash light as glow plug light. AC 60g glow plug conversion. No more burnt up gps. Dana 50 TTB and sterling 10.25 with4.10 gears and limited slip. Custom 5 inch stack from a JohnDeere Tractor and custom push bar/ grill guard. 33 12.50 16.5 Wild Country radail rvts in the rear and brand new BFG All terrains TA KO`s in the front. Shes a beast son. Wish list. New windsheild. New tach and speedo. New paint that matches. Proud BOOB man.
86ford69 is offline
post #3 of 10 (permalink) Old 10-20-2010, 01:47 PM
My Photos: (27)
If not a switch/wiring problem to the shutdown solenoid, sounds like it's hanging up. Should be easy to check with a test light.
Not really, the instant you shut the ignition off you've got no timing.
LMJD is offline
post #4 of 10 (permalink) Old 10-20-2010, 08:55 PM
86ford69's Avatar
Well thats what I was told was th problem. Never messed with it it was just a beater truck.
86ford69 is offline
post #5 of 10 (permalink) Old 10-20-2010, 09:00 PM
big99- you probably have debris in the fuel shut off solenoid. You can remove the top cover to see. If there is debris you need to find where it came from. (possible internal pump damage)
Evel486 is offline
post #6 of 10 (permalink) Old 10-20-2010, 10:05 PM
Joe Mc's Avatar
My Photos: (39)
Re-adjust the ignition switch. Just a quick test the next time it keeps running, reach under the dash and jiggle the linkage on the ignition switch. If it shuts off the the switch is sticky or mis-adjusted, a $10 part from Autozone.
Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW
BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
135,016 miles: Rear-ended and totaled by an uninsured kid having a temper-tantrum
1999 Rav4 AWD 5-speed, AC, PS, PB, CC, Sunroof.
Joe Mc is offline
post #7 of 10 (permalink) Old 10-21-2010, 12:49 PM
Try pulling the wire right off the IP and see what happens. May have to try it a few times if the problem is intermittent. Should tell you if the problem is in the FSS or ignition switch.
Work like there is a tomorrow and play like there isn't.
99 F250 CC LB 4X4 255K AT
85 F250 SC LB 2WD with Banks aftermarket turbo, C6
87 F250 Lariat SC LB 4X4 with an NA 6.9, C6 with deep pan and 4.10's. Dana 50 IFS up front. 263K mi. 3" exhaust, Ram air. New aluminum radiator and coolant filter Sep 09. Parked due to horrible engine knock.
96 F350 CC LB 4X4 AT 292K- creamed by Brain Dead Cager turning left 02/18/10 RIP
DevoK12RS is offline
post #8 of 10 (permalink) Old 10-22-2010, 08:45 PM Thread Starter
i think its my ignition because i tried to take the wire off the ip and it didnt shut off and the key was off so must be the ignition
post #9 of 10 (permalink) Old 10-22-2010, 08:52 PM
rsr911's Avatar
If you pulled the wire from the IP and it didn't shut off then it's the FSS and not the ignition. Did you pull the front or rear wire?
1986 F350 Crew Cab 4wd DRW conversion. 1993 7.3 IDI, 5spd Sterling 10.25 4.10 rear, kingpin D60 4.10 front, 12" HD clutch. A Banks waste gated turbo. Midwest rebuilt IP turned up. AC Delco 6.5 GM 12V GP's, working great. Running W80-W85 high performance zero-gel black diesel! 4wd and dually conversion is done. Washer mod on the D60 kingpins eliminated the death wobble. Custom 10" C-channel front bumper with military D-rings front and rear. Pintle hitch, receiver hitch, and goose neck hitch. 7800lbs full of fuel....
rsr911 is offline
post #10 of 10 (permalink) Old 10-23-2010, 11:12 AM
Yeah, I should have specified- the right, front wire. If you pull it and the truck keeps running, the problem is with the FSS, not the ignition switch.
