Flex-a-Lite Cooling Fan - Diesel Forum - TheDieselStop.com
Old 11-02-2009, 11:33 AM   #1 (permalink)
Anyone ever used the Flex-a-Lite cooling fan in place of the original fan/clutch assembly? If not, know of any rebuild kit or cheap supplier? A new clutch from Ford costs $350! Thanks for your time.
InTheDogHouse is offline
Old 11-02-2009, 12:04 PM   #2 (permalink)
My Photos: (27)
Get one from Napa. By comparing Napa's and Ford's clutch side by side they sure look like they're made by the same vendor.
Just looked on Napa's site. For my '91 the fan clutch is $169. Don't ya just love your friendly local Ford dealer?
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 11-02-2009, 04:38 PM   #3 (permalink)
CDX825's Avatar
My Photos: (11)
Send a message via AIM to CDX825 Send a message via Yahoo to CDX825
Check out the fans from a Taurus. There a few guys running them with good results.
-Justin
1984 F250 6.9 C6 2WD Push Button Wellman GPs, No Soup bowl. Wix 33439 Water Separator, Carter P4594 fuel pump, Custom 3" Exhaust, NTZ Oil Bypass Filter, VDO Vision water temp gauge, ISSPRO EV Pyro
http://photobucket.com/CDX825
CDX825 is offline
Old 11-02-2009, 08:44 PM   #4 (permalink)
Notice that you will need two of the Taurus fans, and that setup only fits one of the two radiator styles available for these trucks.
M.L.S.C. is offline
Old 11-10-2009, 09:57 AM   #5 (permalink)
Mark VIII (8) fan pulls almost as much as the factory fan. There is a HD fan clutch out there for around $200. You can get the Lincoln fan from Recycle yard, eBay, etc. & get a controller from Jegs, Summit, etc.
Rick
Rick
86 F250 N/A 4WD w/HomeGrown Propane, Poly Spring/Body Bushings, PushButton GP Controller, 3.55L rear, Goodyear WorkHorse II XTRA Boots, 248k miles, Rotella 5-40W Synthetic
Rick_Hipp is offline
