Found front D60 need advice - Diesel Forum - TheDieselStop.com
Old 11-28-2005, 01:40 PM   #1 (permalink)
Hey there guys,
I have been looking for a front dana 60 for my pickup for several months and finally found one for $650. It is out of an 86, my question is, will this one work ok for me in my 87? Is it a kingpin style? Any major concerns to look for. Thanks in advance
Ben
2002 F350 CC 4x4
sprdve is offline
Old 11-28-2005, 02:00 PM   #2 (permalink)
Re: Found front D60 need advice
Yes its a kingpin style.You shouldnt have too much trouble installing it.
1992 f-350.4x4 srw.rebuilt e4od.rebuilt injection pump. no soup bowl,no muffler,straight pipe.. 8 foot power angle Artic blade/7 1/2 ft p/a Fisher blade. 280,000kms and counting.Paint to come.
pnose is offline
Old 11-30-2005, 08:52 AM   #3 (permalink)
hesutton's Avatar
My Photos: (30)
Good price. That year does use king pins. I've got a dana 60 I'm installing now and the biggest issue has been the front drive shaft. I'm trying to work out the clearence issue with the tranny crossmember. Dana 60 Post Here
I'm still waiting to find out what needs to be done. It looks like using a F350 tranny crossmember helps, but still need an answer on which drive shaft to use.
Heath
1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
1983 F250 4x4 5.0L with C6. 340,000+ miles.
7.3 Project Pictures
Webshots Project 7.3 Gallery
hesutton is offline
Old 11-30-2005, 10:26 AM   #4 (permalink)
My Photos: (14)
You will need to use the F350 shaft and transfer case yoke. The crossmember in my 87 F250 worked fine with this setup and there was no need to use the F350 crossmember.
1987 F250 6.9 4X4 - T19 Trans, 4.10 Dana 60 Front/Ford 10.25 rear, Dual Rear Wheels, Carter P4594 electric fuel pump, Restrictive air filter opened up, Firewall repair kit installed, new clutch m/cyl and pedal bracket, bushings etc.,7.3 fuel filter conversion, Solid state controller OEM (new controller and Motorcraft GP's), Headlights converted to relay system with 65/100 Watt Cold Ice bulbs, Class V Hitch (10,000lb WC/15,000lb WD), Air Horns, Cadet 7' X 9' flat dump bed, 5 ton grainmaster dump hoist.
sle2115 is offline
Old 12-01-2005, 12:27 PM   #5 (permalink)
So on my 87' I can use the same cross memeber but need the 350 t-case yoke and driveshaft? I will let you know what comes of this mod as it happens.
Thanks,
Ben
2002 F350 CC 4x4
sprdve is offline
