FSV problem - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 04-06-2008, 08:40 PM Thread Starter
jabink89's Avatar
FSV problem
i have been having a problem since i put my truck on the road since restoration and am now just getting around to fixing it.
say i have a half a tank in the fron tank and i fill up the rear tank and run my truck on the rear tank.
after i shut it off for the night and come out and start it up switch it to the fron tank it reads full.
the valve switches back and forth perfectly but it seems to me that when switched to the rear tank the front doesnt seem to close and gravity fills the tank up over night.
any information as what to do and look for when im underneath would be greatly appreciated as this is one part of my truck i have no idea about.
thanks
JOSH
jabink89
1988 F250 ext. cab dually 2WD 4.56 rear
7.3 W/ ATS Turbo kit, HEAD STUDS, ZF5 single mass flywheel, 12.5 clarck clutch, 6" stacks, mickey thompson supersingles for the summer time.
American flag paint
boost/pyro/oil temp/oil press
1986 f250 Lariat 4x4 6.9L c6 auto/285-75-16's/ brand new viper red paint with my own custom interior viper red and black to match body/front flare out fenders to match newer body style bed from a 95 (custom)
jabink89 is offline
post #2 of 11 (permalink) Old 04-07-2008, 07:53 AM
WhiteGardens's Avatar
Is your tank actually filling up or is you sending unit shot.
THE BLUE BOMBER! Currently Toast !!!!
87 ford f-350 cab-chassis dually. 2wd, 6.9, 3 speed C-6. 3 leaf helper springs, 11,000 gvwr, pintle/ball hitch, 6 pin round trailer connector (unhooked currently). Rear generic truck stop lights. Twin I beam front end with coil springs. Plow lights and switch to go from headlights to plow lights. 8.5 foot meyer diamond plow with central hydrolics. 8 foot rugby dump bed. 167,000 miles and still strong. Solid State Glow Plug Controller.
WhiteGardens is offline
post #3 of 11 (permalink) Old 04-07-2008, 01:06 PM Thread Starter
jabink89's Avatar
my tank is actually filling up i thought that at first and checked but the tank is filling up for sure
jabink89
American flag paint
jabink89 is offline
post #4 of 11 (permalink) Old 04-07-2008, 03:25 PM
NCheek's Avatar
You say this has only happened since restoration, is it a possibility that you might have gotten the plumbing mixed up?
-Nick
1986 F-250 2WD, Regular Cab, LWB, 6.9, T-19, Sterling 10.25", open 3.55's, XLT Lariat, Texas Sesquicentennial Limited Edition, No Restrictor Plate, manually switched high idle/advanced timing, and an awesome custom shift knob thanks to Bruce Roosa / Koolknobs.
279,000 miles and counting, hoping for a US Gear OD and a Hypermax Turbocharger one day.
My first truck:
1982 F-250 4WD, Extended Cab, LWB, 5.8, C6 to T-19 swap, BW 1345, Dana 44 TTB/Dana 60 Semi Floater, open 3.55's. About four different colors (not counting rust), currently on loan to my little brother. Maybe one day it can be home to a 6.9L too.
Work Truck:
1992 F-700 Flatbed w/ dump, 7.0L BIG BLOCK GASSER, 5-speed trans (Clark?), 26,000 lb GVWR. Rides like a tank
NCheek is offline
post #5 of 11 (permalink) Old 04-07-2008, 03:53 PM Thread Starter
jabink89's Avatar
very well could have but it was never tampered with by me maybee the P/o so i cant rule it out
jabink89
American flag paint
jabink89 is offline
post #6 of 11 (permalink) Old 04-07-2008, 06:36 PM
Is it possible your fuel selector valve isn't closing all the way. That might explain the siphon effect you are having.
If it were me, I would change the selector valve and rule that out. I think that's the only spot where the two tanks are connected. I wouldn't think your getting a siphon from your fuel return line, seeing how it has to go through the fuel pump and ip pump for that to happen.
post #7 of 11 (permalink) Old 04-07-2008, 08:44 PM Thread Starter
jabink89's Avatar
thats what im thinking that it isnt closing and becuse of this it fill up over night since the rear tank is higher.
i will just replace it but i cant find any new ones ford no longer carries them according to my local dealer
anyone know where i can get a new one
if not i can take one off my parts truck but would rather have a new one.
jabink89
American flag paint
jabink89 is offline
post #8 of 11 (permalink) Old 04-07-2008, 09:13 PM
suv7734's Avatar
I don't know anything about the quality etc but here's one that's available: AutoZone.com | Shopping | Parts | Product Detail - Fuel Tank Selector Valve
For every action there is an equal and opposite malfunction
1988 F350 CC 4x4 SRW, 7.3 Banks non-wastegated turbo, C6 w/ HD torque converter, Tru-Cool 4590 trans cooler, Highjacker 'softride' 4" lift, pre/post luber, coolant filter, Racor fuel filter/separator, pyro and boost gauges, Progressive 16x8 wheels, 285-75x16 rubber, 3" downpipe into 4" straight pipe over the rear axle and into 5" SS tip. 1994 Alpenlite 33' 5th wheel trailer
suv7734 is offline
post #9 of 11 (permalink) Old 04-07-2008, 10:12 PM
i have a used one out of an 87 f250 if you want it give me a pm
ASE Certified: Medium and Heavy Truck Diesel
Federally certified air brake technician
1990 F-250 7.3 IDI N/A 4x4 ZF5 Dana 60 front, LUK Clutch SMF, 215k
1991 Ford B700 6.6l School bus, Straight pipe
1987 Ford F350 Dump 4x4 c6, 38k miles, 8 foot meyers plow
2002 VW Golf TDI
1989 Festiva (my favorite)
1989 Saab 9000 Turbo
2002 Saturn SL1 (Daily Driver)
1950 Dodge Coronet
1996 F150 2wd 4.9 5 spd, 136k
90734x4 is offline
post #10 of 11 (permalink) Old 04-08-2008, 11:09 PM
RonRN18's Avatar
Are the 86 and 87 FSV the same? I went to my dealership and they still had them, in fact they said they had one on the shelf. The FSV is the same as what they used for several years since (I'm not sure how long, but it was into the 90's) and they could still order them. I asked about both the FSV and the sending unit, as none of the auto parts stores listed them. I've seen universal FSVs, but they require a wiring adapter. I think the FSV would cost me $121 and the sending unit was $117 (with an employee discount... list price was around $160-180... our fleet mechanics at work are Ford-authorized mechanics and do a LOT of business with the dealership... our entire fleet are Fords.)
RonRN18 is offline
post #11 of 11 (permalink) Old 04-09-2008, 07:23 AM
cdnsarguy's Avatar
My Photos: (109)
The newer style FSV was for 88-97 but due to the 87 being a crossover year there may be a newer style on some trucks..... late builds maybe. If anyone does a replacement please post what you find that fits......with part numbers so I can stash that info........ thanks.
Proud Canadian BOOB man too!!
cdnsarguy is offline
