First, I'm new to the site so thanks in advance for any comments
Working on a project truck that started out as a 1985 F250
Right now I'm working through a cummins swap
I have a stock C6 with a gear vendor but don't expect the torque converter and transmission to last very long.
Has anyone out there ever tried an E4OD with an aftermarket transmission controller and a gear vendor? Tried the search function but didn't find anything.
Boblikestorque
1985 F250 - with a cummins
The C6 is a strong transmission, the E40D, commonly called the DOA, has a reputation for problems.
__________________ Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
Triple A-pillar pod: Isspro EV voltage and oil-pressure gauges.
Road-Watch System (Air and road-surface temperature gauge).
Chicken Lights Gone.
The C6 is a very strong transmission as Joe mentioned and is allot more reliable than a E4OD. The C6 will take any HP a cummins can throw at it even in stock form they are very strong.
An E4OD can be made as good as a C6 as they are basically a C6 with OD but the early models had lots of issues. Unless your getting one with all the updates already you will drop allot of money quick in order to bring one up to date.
There are quite a few guys using E4ODs with Baumann TCS controllers but the only thing you really gain with and E4OD is a locking torque converter.
All depends what your looking to do really.
-Justin
1984 F250 6.9 C6 2WD Push Button Wellman GPs, No Soup bowl. Wix 33439 Water Separator, Carter P4594 fuel pump, Custom 3" Exhaust, NTZ Oil Bypass Filter, VDO Vision water temp gauge, ISSPRO EV Pyro
Now Mark, just how hard was it to restrain yourself to 5 words?
Diesel Mechanic 28 yrs
If you are going the C6 / GV route be sure you use a P type GV, the J type earlier one is a little weak. I have C6 GV combo in my 86, works very nice. Very nice to run 2nd gear overdrive which ends up 1/2 way between 2nd and 3rd in the mountains. Picke up 1.5 MPG on long trips, nothin locally. The way I see it you have a trade off: No electronics on one hand vs lock up torque on the other. I like my C6, but lockup would be cool too.
C6 is strong - no doubt about it. From what i gather, to have a custom torque converter built, the lower limit on stall speed is about 1400 rpm - before one starts to sacrifice strength. And then it’s not a lock up.
Nirvana to me looks like – 4.10 gears, 33 inch tires, double overdrive, 70mph, 1400 RPM, lock up TC and huge mileage – without a trailer of coarse. Should be able to pull 14,000 lbs like it wasn’t there as well.
No doubt, would have to open up the wallet for a well build E4OD.
Really aiming towards a tow rig but there will be lots of 5 hr light duty highway trips as well.
Boblikestorque
For several years I have researched the auxiliary overdrive option and just remembered seeing this somewhere...
I read that the GVs have a problem with the Cummings engine, not sure which version though. It was something about torque pulses. I would do some research on this to avoid a possible problem later. Who knows, GV may have modified their design to handle this issue.
02 SWB CC 4x4 auto, AIS, DPTunerF5, FTVB, 4" Banks Monster SS Exhaust, HPOXover, AirDog, Amsoil ByPass, Centramatics
