Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > 6.9L Diesels
Old 08-31-2008, 05:49 PM   #1 (permalink)
Question Glowplugs
i have a 86 f-250 with a 6.9 and i was wondering what the glowplug looks like in that motor. because the plugs that are in here are not spade conector they have a round contector on there. are they the right ones for my truck.
i heard beru's are good where can i get them and how do i test them
hepp25 is offline
Old 08-31-2008, 07:17 PM   #2 (permalink)
CDX825's Avatar
My Photos: (9)
Send a message via AIM to CDX825 Send a message via Yahoo to CDX825
They switched the plug style in 87. Check ebay for glow plugs. I got my set of wellmans witch are just as good as beru's for like 67 and some change shipped to my door. To check the plugs you need a ohm meter or a test light. ohm reading should be 2 ohms or less. If you use the test light it just needs to be lit.
1984 F250 6.9 C6 2WD Pushbutton Wellman GPs, True Flow air filter, 7.3 IDI air cleaner Cover with no Soup bowl.
CDX825 is offline
Old 08-31-2008, 07:18 PM   #3 (permalink)
chuckster57's Avatar
Sounds like you may have the "bullet" connector GP's . they are Ford ZD9's. You can get them here 6.9 Ford Diesel parts Fuel Injection Turbocharger
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually,
1997 Jayco fifth wheel 323 RKS, Robins 16K dual axis hitch
Apillar pod with: Autometer C2 Series gauges: pyro,trans, boost
Hypermax Cowl induction, Flex-A-Lite 26K tranny cooler w/fan
K&N air filter (we'll see in a million miles)
Tekonsha "prodigy" brake control
Train Horns: Pictures here
chuckster57 is offline
Old 09-02-2008, 03:09 PM   #4 (permalink)
If he has a 6.9 he should have the spades the 7.3 s had the bullets . so he might have a 7.3 or wrong plugs. Correct? when I swapped engines quite of few people told me I couldnt use the 6.9 plugs in the 7.3. I check the spec's and the only differnece i saw was the connectors. But I decided to put the correct one's for the engine back in.
1988 F250 6.9 Diesel Ext Cab. No mods YET
1994 F150 Ext Cab 4W/dr
1994 f150 5.0 Ext Cab 2w/dr
1991 Ford Ranger Ext Cab 4w/dr
1966 Dodge Charger 383 4Brl w/Facorty a/c
diesel dad 96 is offline
Old 09-08-2008, 01:57 AM   #5 (permalink)
I had the bullets in my 86 F350. Someone swapped them in and used cheap bullet connectors. 3 of the tips on teh GP's were blown out, I dont know if it was because of them being Autolites, the wrong GP's, busted GP controller or use of ether. I ordered some motorcraft spades and will be redoing the connectors on the harness just to make sure.
in2fords is offline
Old 09-08-2008, 12:12 PM   #6 (permalink)
thanks
hepp25 is offline
