Good RPM range for my truck - Diesel Forum - TheDieselStop.com
Old 11-26-2005, 10:33 PM   #1 (permalink)
Hello all [img]/ubbthreads/images/graemlins/smile.gif[/img]
Well I got my tach working and now I am wondering what is a good range to stay in for RPM's? What is the highest I should go (not that I am going to try to redline it, but still it would be nice to know [img]/ubbthreads/images/graemlins/smile.gif[/img]
I remember with my all the IH's that I have owned they really aren't high reving motors, and all the more heavy duty IH's that I have driven they have been low revign motors.
Anyway, what is a good range to stay in? I don't want to lug my engine but I also don't want to over rev it [img]/ubbthreads/images/graemlins/smile.gif[/img]
Thank you all for the help,
Luke
87 Ford F-350 4X4. 4 speed manual.
BCbinders is offline
Old 11-26-2005, 11:19 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Re: Good RPM range for my truck
Need the rear axle code from the door label........35,39,C5,C9
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 11-26-2005, 11:53 PM   #3 (permalink)
Unless your pump has been monkeyed with, it won't allow the engine to over-rev.
They reach a certain point and that is all they will do.
Lugging never seemed to hurt these old engines, but I would probably run from 1700 to 3200 and go from there.
1985 F-350, 6.9 4spd, Hypermax, 3.55 rears
BullHauler is offline
Old 11-27-2005, 12:53 AM   #4 (permalink)
The axle code is C9, the trans code is K as well [img]/ubbthreads/images/graemlins/smile.gif[/img]
Thank you
Old 11-27-2005, 01:00 AM   #5 (permalink)
If I read correctly, C9 is a 3.55 limited slip axle. and trans code K is a auto tranny? My truck has a 4 speed manual. Hmmm, maybe that means it was swapped in. I think I am going to need a clutch soon so maybe it doesn't have a dual mass flywall.
Old 11-27-2005, 01:16 AM   #6 (permalink)
Should have the SMF if it is a 4-speed. The crappy dual mass came with the ZF-5 which is a great tranny but the stock wheel will sooner or later need replacing. Your peak power band is around 1700-2500, above that you don't gain much. If the governor is working properly and teh pump is truly stock you should not be able to hurt the motor by standing on it. these governors are sort of soft they will allow ith to rev anywhere from 3300-3800RPM, which should still not leave you floating valves under normal circumstances. But I hate to redline it for very long. You also face a seevr fuel mileage penalty for every RPM over 2500 which is why your 3.55s are nice!
J.D.'s Fords: 1986 F-250 6.9 diesel Solid State Glow Plug System 3.55 gears C-6 2WD 178,960 miles.... it still runs pretty good!
Wishlist H-max turbo, T19 tranny,
1989 Ford Ranger ga$$er, non runner, soon to be donated or scrapped!
jdkline is offline
Old 11-27-2005, 06:20 AM   #7 (permalink)
If I have the 4 speed tranny, what ratio is 4th gear? Is it 1:1? If so then at around 2500 RPM I would be doing a little over 100 KM/hr [img]/ubbthreads/images/graemlins/smile.gif[/img] That would be nice [img]/ubbthreads/images/graemlins/smile.gif[/img]
Old 11-27-2005, 12:13 PM   #8 (permalink)
Joe Mc's Avatar
My Photos: (39)
4th is 1:1.
Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW
BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
Triple A-pillar pod: Isspro EV voltage and oil-pressure gauges.
Road-Watch System (Air and road-surface temperature gauge).
Chicken Lights Gone.
Joe Mc is offline
Old 11-28-2005, 10:46 AM   #9 (permalink)
If you are into "projects", you might consider an overdrive unit to get the rpms down a bit (multiply your rpms by .8 to find the rpms in overdrive). Gear Vendors is light duty, smooth in operation. US Gear is heavy duty, a bit clunky in engagement (I still haven't figured out how to make it smooth).
If you don't have anything to do, get a used diesel and a camper!
Truck 1: 1985 F350 dually 4WD 6.9 diesel crew cab auto with 83k original miles. C6 trans, 4.10 rear end. Mods are Banks Turbo, US Gear overdrive, 45gal rear tank, hydroboost brakes, additional leaf springs all around, Hellwig airbags, rear sway bar, GM glowplug controller, fuel Koalescer. 235/85 R16 Michelin XB Rib radials. 11ft.6in Vacationeer cabover camper, TorkLift tiedowns.
Truck 2: 1988 F250 7.3, C6 auto, 2WD w/3.55 limited slip rear axle, Banks Sidewinder Turbo, Gear Vendors overdrive, Utility box, hydraulic lift gate, lumber rack.
Auto: 1987 MBZ 300D Turbo 3.0 Liter 6 cylinder engine. 205K miles. Working on all the "little things" that previous owner neglected. Putting in wvo tank.
Monte1 is offline
