GVWR, GCVWR for '85 F-350 dually flatbed? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 12-26-2010, 04:19 PM Thread Starter
My Photos: (6)
I just bought an '85 F-350 dually flatbed, 4 speed, 6.9 liter. I also picked up a couple of repair manuals (Haynes, Chilton) but they did not list any weight ratings, either hauling or towing. Any ideas?
Also, I have been a member here for years and learned a lot regarding my '02 PSD. This will be my local shop truck. Any suggestions on maintenance or low cost power mods?
ToddT is offline
post #2 of 7 (permalink) Old 12-26-2010, 06:30 PM
fordf350flatbed's Avatar
my 85 flatbed is 10k. and do the soup bowl get a pyro and turn the pump up as well as exhaust. they are cheap and easy. im 17 and did it. anyone can haha. also turbo would be nice on it. i plan on gettin one.
85 ford f350 6.9 flatbed dually. soup bowl mod.ip up 2 flats. Autometerc2 pyro 4 inch ofset stack with a flapper black wheels smoked cab and tailights and .mirror mount whips, a cb, dual head unit with sony explodes, and soon 4x4 mabe a sub and some navistar mud flaps. Yes a cab and chassis with a sub
(my first truck)
[FONT=Arial Black] 04 ford f250 4dr shortbed 4x4 6.0. . (grandfathers truck)
09 ford f350 V10 4dr longbed 4x4. banks monster exhaust. chews up chiped 6.0s / 7.3s and spits em out. (dads tow rig)
fordf350flatbed is offline
post #3 of 7 (permalink) Old 12-26-2010, 09:04 PM Thread Starter
My Photos: (6)
When you say 10k, I'm assuming that's the tow capacity?
Thanks for the tip. Found a description on the soup bowl mod. Sounds straightforward.
What are the options for upgraded exhaust? Haven't found anyone with aftermarket down pipes. I bought a '93 7.3 just before the Powerstrokes came out and remember how restrictive the factory exhaust was back then.
Is there much external hardware that is shared by the 7.3 PSD and 6.9? I'd love to upgrade my '02 and create some "hand me down" mods for the 6.9. Exhaust? Starter? Turbo?
ToddT is offline
post #4 of 7 (permalink) Old 12-26-2010, 10:35 PM
vegoildieselguy's Avatar
ToddT Welcome!
he means 10,000 GVW, I'm sure you know it is a 1 ton truck that has over 8500 GVW. For exhaust I wouldn't go smaller than 3 inch, but any bigger isn't required either. Dynomax sells a 3 inch downpipe/y pipe but you might have to modify the firewall to make it fit. No hardware is the same between those two engines, they are totally different blocks. Powerstroke changed the design of the IH Navistar IDI's so you will not be able to interchange parts except for a oil filter maybe...
1985 Ford F-250 w/ freshly rebuilt 6.9 diesel, reg. cab, 2WD, zf-5, 10.25 rear, short throw exhaust 2.5" down pipe to 5" to 7" tip, Banks non wastegated turbo, Isspro pyro, Isspro Tach., custom flatbed 9' long x 7 1/2' wide, 3g alternator, push button gp's, memphis audio sound w/ kenwood stereo and amp, Toredor Red and Cream white. Practically restored. 6500lbs
vegoildieselguy is offline
post #5 of 7 (permalink) Old 12-27-2010, 06:50 AM
drinkypoo's Avatar
My Photos: (25)
It doesn't take a 1 ton to be over 8500, F250 came up to 8800 in 1992 and contemporary chevys are 8600
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #6 of 7 (permalink) Old 12-27-2010, 08:57 AM
you can go to your local napa for the dynomax downpipe. they can order it. they actually make a really nice system for these trucks
(my first truck)
post #7 of 7 (permalink) Old 12-27-2010, 10:44 AM Thread Starter
My Photos: (6)
Thanks for the info. Now I just need to take my truck across the scales.
By the way, I also run veg oil. I bought the truck specifically to become my "shop" truck for collecting grease. I have a small chemical company which I run entirely on bio.. my other truck as well as a diesel generator for electricity.
Have you converted your 6.9 to run on heated WVO or are you running biodiesel?
ToddT is offline
