Hard start (better than it was) and dies every so often when RPMs lower quickly - Diesel Forum - TheDieselStop.com
Old 11-25-2012, 02:07 PM   #1 (permalink)
Diesel guys,
I have an 85 F250 4x4 with a 6.9 and live in Atlanta, GA.
I really love this truck.
I was recently having a really hard time starting the truck, so replaced fuel injectors and glow plugs. both really needed replacing.
Now it starts significantly better, but if I let it sit for a day or two, it really struggles to crank, but eventually will. (before, i would have to have to have it it plugged in to start.
Also, the engine has died a couple times. I have noticed it is when the RPMS lower significantly like coming to a stop.
Other than these things, the truck drives like a million bucks (especially after the new tires and u joints i just put on it .
Since I have replaced the glow plugs and injectors, does anyone have any thoughts?
Hard start (better than it was) and dies every so often when RPMs lower quickly-big-red.jpg
djgendron is offline   Reply With Quote
Old 11-28-2012, 11:57 PM   #2 (permalink)
arthurgoboom's Avatar
Regarding your sudden shut off when RPMs drop rapidly, I have experienced this. I believe something in the governor inside the pump got sticky. I was able to fix it by holding the throttle wide open then side stepping it so it slammed back to idle. Did this for a few minutes with the engine off, and it seems to come back to an idle now without dying.
I blame my WMO use for this, but it may also be from sitting unused for a long period of time.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Wellman G088 glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline   Reply With Quote
Old 11-29-2012, 02:49 PM   #3 (permalink)
Thank you for the reply. Your comment about sitting makes sense. It is not an every day driver and does sit for a week or so at a time. I will follow you advice. Thanks again
