Heater Hose Block Heater - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 03-30-2006, 02:48 PM Thread Starter
Does any body know where I can get an electric coolant heater for my 6.9 that I can plumb into the heater hose? I know I have seen them before, just can't find anything... After the crack I am dealing with now, I will not use a freeze plug style block heater ever again....
Mike Strickland
Web Master
BigCountryOff-Road.com
2003 F-450 4x4, 6.0 PSD, 4.30 Gears, Western Hauler, 19.5 Wheels/Tires; EGR Delete, ARP studs, HPOP, bypass fuel system, cold air intake, EGT gage(more to come), SCT tuner
RajinCajun is offline
post #2 of 9 (permalink) Old 03-30-2006, 02:53 PM
Re: Heater Hose Block Heater
Mike,
I would imagine most, if not all auto parts stores would have them, or should be able to get them. Perhaps someone like J.C. Whitney would have them. Tim
'94 F250, 4X4, 7.3, E40D, 4.10, 147K
tim94f250 is offline
post #3 of 9 (permalink) Old 03-30-2006, 07:45 PM
TMH
I bought mine at a heavy truck parts store.
The brand was zerostart 1000w 120v it gets
conected inline on the heater core hose.
cost was around $50.00 part#3305002
hope this helps.
88 E250 Club Wagon xlt 7.3 IDI NA C-6 3.55 171,000
p/w p/l a/c f/r 4 capt. bench/bed 4 ar chrome rims
215 85 16 fronts, 265 75 16 m&s rears
tilt c/c stock for now.
2 new batts, 8 new gp
83 F250 2wd xlt 6.9 extra cab 4spd. 3.54 Capt. chairs rear bench tan & brown needs work. pd $650
and it runs. 255,000 well used miles.
aftermarket tach, stock y pipe to 4 inch exh,
4 inch muffler, 4inch tail pipe
2 new batts, 8 berus,pb glow
1000w coolant heater (to be installed soon)
88 f250 2wd. xlt sc long bed 7.3 5spd. 240,000 miles pw. pl. ac. cruise, tilt, stock.
needs gp,batts,tires.
rebilt ip
TMH is offline
post #4 of 9 (permalink) Old 03-30-2006, 10:11 PM
<font color="green">Mine is a KATZ I think.
It is very important to mount these below the level of the water-pump, the lower, the better.
This is so that the heat can go up and circulate the coolant.
If you simply mount it in the heater hose, it will only warm the water above it and not the engine.
I installed a fitting in the drain-cock opening of the radiator and mounted the heater beside the frame-rail, then ran a hose up in front of the radiator and "Y"ed it into the heater hose that mounts in the side of the block.
The cold water leaves the radiator, is heated, and the hot water travels up and over, entering the block, and warming the engine.
On a zero day, plug in for two hours and it will start like July.
</font>
1985 F-350
5.9 CUMMINS TURBO DIESEL
G360 GETRAG 5-sp
3:55 DANA 70
LongRider is offline
post #5 of 9 (permalink) Old 03-31-2006, 10:41 PM
My Photos: (13)
Most farm supply stores carry them.
-----------Robert
'92 F-350 Crew Cab dually,7.3 5 spd+ 3 speed Spicer 5831 Brownie, Solid Flywheel w 12 1/4" Kevlar Clutch, ATS turbo, Hypermax Cowl induction, MS Tech Fan Clutch, Custom Aluminum Rodney Red Radiator, 4" Exhaust, Air seat, Western Hauler bed.
RLDSL is offline
post #6 of 9 (permalink) Old 04-03-2006, 02:14 PM
there are the type that go into the lower radiator hose as well, but I prefer the canister style, which is what you refer. They are circulating style, and the actual proper way to hook them up is to go through the drain plug and t- into the heater hose, that way you get better circulation.
86 F250 4wd, 6.9, T-19 trans, 4.10 axles, opened up the intake, fabbed 3.25 exhaust to self made muffler, 3.5 out to 4" tip. GM prefilter/water separator, Holley Red fuel pump.
92 F350 2wd crew cab, 5.9 Cummins with A518 auto, 4.10 axle, gear vendors overdrive.
fellro86 is offline
post #7 of 9 (permalink) Old 04-03-2006, 03:32 PM
Autozone carries them.
The up side to the radiator-hose mounted heaters is they are much easier to install.
Before buying a canister-type heater, I suggest you make sure you can get your block drain plug out, as you must run a hose to that hole to use the canister heater.
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
post #8 of 9 (permalink) Old 04-03-2006, 05:49 PM
Tractor Supply Company Carries them. They are relatively inexpensive there. I have one on each of my vehicles and they are great. They don't have them on their website but most of the stores do carry them. autozone and oreillys have them too.
85 Ford F-250 6.9
TheStoneDoor is offline
post #9 of 9 (permalink) Old 04-04-2006, 09:43 AM Thread Starter
Thanks a lot everyone... I just did not remember seeing them at all around here...but then again, I wasn't looking..LOL!! I will do some checking locally at the places you recommended..
Thanks again for the info.. I will see what I can find.
Mike
Mike Strickland
Web Master
