Help !!!! - Diesel Forum - TheDieselStop.com
Old 08-26-2007, 02:50 PM   #1 (permalink)
Help !!!!
Hauling a load of sand in my '85 F-250 smoke started rolling from under the bed, Wires along the drivers side of frame rails were red hot and melted so I cut them close to the cab, Ended up burning completely the sending unit wires to the rear tank,ground wire to front tank and a main always hot wire in the other harness (I suspect this is where the prob started) My problem is the plug that goes to the rear tank is ruined, Do I need to go to a bone yard to get a new plug or is there a online source for this type of item? also I am having a hard time finding a schematic for the fuel system wiring beyond the fuel pumps, am I better off finding a donor truck to pull the whole harness for the rear of the truck and splicing it in ? Any help is greatly appreciated
Huntr is offline
Old 08-26-2007, 04:15 PM   #2 (permalink)
arthurgoboom's Avatar
Re: Help !!!!
There's no wiring for the fuel pumps, you have a mechanical fuel pump on the engine. There are only 2 wires going to each fuel tank, for the fuel level sending unit. Some of the other wires going back there are for the tank selector valve, or maybe one of the wires that burned is for the rear lights.
I think if you check with autozone or advance auto they'll have a pigtail for the top of the fuel tank sending unit. If I remember we bought one for a Ranger before.
Here is a complete wiring diagram, this is for '86 but I think it should be similar. http://community.webshots.com/album/202816966sObdCc
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Wellman G088 glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 08-26-2007, 07:59 PM   #3 (permalink)
Re: Help !!!!
go to a scrapyard diesel--and get the harness---thats unusual for that to happen----
94_turbo is offline
Old 08-27-2007, 02:01 PM   #4 (permalink)
skunk's Avatar
Re: Help !!!!
"chilton repair and turn up guide for ford pick ups 1965-86" covers it. check it out at the librairy.
Northern Woodland & Tree Care work trucks:
old smokey
- 86 Ford F250 6.9 IH navistar non-turbo idi diesel 4x4 dana 60 rear w/ limited slip, dana 44 front wishbone style, w/ 3.55 gears, C-6 w/ oil coolers, manual walbro frb-13 fuel pump, manual wellman glow plugs, K&N air filter no soup bowl and a homemade cold air intake, 3 inch pipe, class 31 heavy duty tractor truck batterys, lots of real gauges.
big drippy - 86 Ford F350 4 door crew cab, long box, 7.3 Navistar IDI non-turbo diesel, 2wd Dana 70 dually rear with 4.88, c-6 w/coolers.
The Swan - 87 chipmore wood chipper chuck and duck old school style. vm motori sun 4505 3.9 air cooled non-turbo DI 4 cyl diesel, rockford pto.
skunk is offline
