Any suggestions? It has new alternator, voltage regulator, lights come on but when i turn the key to start.... everything dies including the battery. I had to jump start it today. I noticed the headlights flickering the other night and I could hear a ticking sound under the hood. Can't figure out what the problem is.
**THANK YOU TO ALL THAT RESPONDED WITH THESE GREAT TIPS. I WILL GIVE THEM A SHOT. I KNOW THERE'S AN ANSWER HERE SOMEWHERE. THANKS AGAIN!**
Check your battery cables, especially the both ends of the ground cables.
Then pull the starter and have it tested. If all that is ok then start checking the fuseable links and connectors on the passenger fender-well area.
__________________ Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
Triple A-pillar pod: Isspro EV voltage and oil-pressure gauges.
Road-Watch System (Air and road-surface temperature gauge).
Chicken Lights Gone.
I too would check the grey plug herness that powers the body. It's on the passenger wheel well and should have larger wires/fusible link coming out of them.
That yellow connector is a known problem area, burns up inside and the yellow wires do not contact good. Some members have soldered all the wires and heat shrinked them individually.
Proud Canadian BOOB man too!!
not trying to be obvious, but are your batteries/connections on batteries good? I had starting probs then I looked at the dates on the records and they said "New Batteries 05/10/99" so.... i need new batteries!
My new baby:1985 F-250 6.9 non-turbo 236,000 miles, 4x4, 4 speed, 3.54 gears, true dual 3 inch exhaust, turned up IP. If it ain't smokin, it must be broken!
Daily Driver: 2006 Cobalt SS 2.4 Automatic 73000 miles.
My old baby: 1983 F-250 6.9 non-turbo IDI, 86500 miles, 4x4, T-19 4 speed, 4.30 gears, high idle/IP timing advance switch, no soupbowl, and very little exhaust piping. She's loud and I'm proud.
If EVERYTHING dies when you start cranking, then your batteries are likely shot. But you should make sure to check all your battery connections, too. Both can cause the problem you describe, but poor battery connections will eventually eat your batteries.
86 F250 Extended cab, 4x4, T-18/T-19, custom drive shafts. Time for axle upgrades.
you might try checking the power wire going into your voltage regulater box. if it doesent have power into it it will not return a dharge to your batteries and that will cause some same effects. mine got corroded inthe middle of the harness and i like to never figured it out.
Is your voltage regulaor grounded well? I have the same problem in my 86 and it was because the voltage regulator wasn't grounded well enough. It would drain the battries and it sarted going through headlights and alternators.
If you are talking about a one time deal, we had this happen with an 85 we brought home a couple weeks ago. Started and ran fine for the test drive.
But the truck ended up barely making it home 3 hours later. The batteries were so low at that point that the lights were dim and electronic signals, etc. started to tweak out.
So we charged the batteries back up and went under the hood the next day and jiggled some wires in the voltage regulator area and noticed bad connections that would cause the truck to surge while idling.
Then there was a ground strap that should be bolted in and that was completely off. These are little things we did not notice at the time at night, and learned real quick
Anyways we cleaned off various contact points for better connections and ended up having to replace some wiring in that area and reattaching the ground.
So the alternator wasn't allowed to even do its job and it made for wierd things happening during normal operation upon first start after we recharged the batteries.
The symptoms you mention sound exactly what ours was like when trying to restart the truck after the initial problem showed itself with the clicking, low batteries, pulsating lights, etc.
