How to tell if the injector pump is going bad - Diesel Forum - TheDieselStop.com
post #1 of 38 (permalink) Old 08-21-2006, 04:56 PM Thread Starter
Spencnaz's Avatar
My Photos: (14)
I'm curious as to the symptoms of an injector pump going bad. I'm not sure as the previous history of the IP on my truck, it has paint on the IP adjustment screws preventing tampering, is this typical of an original IP or a rebuild?
At 186k miles I would have though that the original IP would have been changed out ages ago.
The Green Monster
: 2001 F250 Powerstroke, 2WD, ZF6 transmission. Bully Dog GT Tuner set in tow mode. MotorSilk boric oxide added to engine, transmission and diff. Showing 30mpg on the freeway running home brew biodiesel. NTZ 1/2 Micron bypass oil filter. Dieselsite coolant filter. 4" open turbo back exhaust. Ford AIS intake. Donaldson ELF7405 oil filter. Caterpillar ELC next on the list.
Spencnaz is offline
post #2 of 38 (permalink) Old 08-21-2006, 08:39 PM
Re: How to tell if the injector pump is going bad
<font color="green">There is no set in concrete life-span for injector pumps.
I have seen abused, neglected, pumps that never had a regular filter change, last for a million miles.
I have also seen the same brand/style pump, cared for religiously, give it up at less than 50,000.
A sure sign of pump weakening is having to crank a long time before starting.
Of course, with an IDI engine, this is a symptom of more than a dozen possibilities.
Weakening down, like a stopped up fuel filter will do, is also a good indication of a pump in need of rebuilding. </font>
1985 F-350
5.9 CUMMINS TURBO DIESEL
G360 GETRAG 5-sp
3:55 DANA 70
LongRider is offline
post #3 of 38 (permalink) Old 08-21-2006, 10:30 PM Thread Starter
Spencnaz's Avatar
My Photos: (14)
Well the truck has good power but a loud knocking sound is coming from it.
The truck starts right up but the knocking noise comes and goes after the engine gets warm. It sounds like it may be coming from the IP, but it's loud underneath the engine.
I sure hope that I dont have a rod knock, I don't think so as the knocking noise isnt constant it will come and go.
I really want to make sure it's an IP before I lay down another 400 bucks on this truck.
The Green Monster
Spencnaz is offline
post #4 of 38 (permalink) Old 08-22-2006, 12:41 AM
<font color="green"> I don't think it is the injector pump.
If it is the pump knocking, it will soon be obvious.
I don't believe the fix is going to be so easy as replacing the pump. </font>
1985 F-350
G360 GETRAG 5-sp
3:55 DANA 70
post #5 of 38 (permalink) Old 08-22-2006, 09:46 AM Thread Starter
Spencnaz's Avatar
My Photos: (14)
Alot of the signs I'm hearing/seeing are pointing to a leaky exhaust manifold or pipe.
Engine power is just fine. I've posted a similar question under what a bad exhaust gasket sounds like. Judging from the noise it sounds like a pumping noise.
The Green Monster
Spencnaz is offline
post #6 of 38 (permalink) Old 08-22-2006, 02:46 PM Thread Starter
Spencnaz's Avatar
My Photos: (14)
Well with another friend listening to the engine, the noise is up high in the engine.
I may have to bleed the injectors and see if the noise goes away.
The Green Monster
Spencnaz is offline
post #7 of 38 (permalink) Old 08-22-2006, 05:58 PM
loose injector or glo plug???
1992 f-350.4x4 srw.rebuilt e4od.rebuilt injection pump. no soup bowl,no muffler,straight pipe.. 8 foot power angle Artic blade/7 1/2 ft p/a Fisher blade. 280,000kms and counting.Paint to come.
pnose is offline
post #8 of 38 (permalink) Old 08-22-2006, 07:02 PM Thread Starter
Spencnaz's Avatar
My Photos: (14)
I think I found the cause, loose vacuum fitting. The sound was coming from the area of the brake booster, when I fiddled with the elbow on the booster, the noise went away.
The Green Monster
Spencnaz is offline
post #9 of 38 (permalink) Old 08-22-2006, 08:26 PM
h2odrx's Avatar
WHAT???? [img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img]
Remember, we aren't eating this stuff, we're turning it into diesel fuel. Your truck only cares about viscosity, acidity, and BTUs. Nothing else. -unknown?
NC State law defines biodiesel as ''any fuel or mixture of fuels derived in whole or in part from agricultural products or animal fats or wastes from these products or fats.''
h2odrx is offline
post #10 of 38 (permalink) Old 08-22-2006, 08:41 PM Thread Starter
Spencnaz's Avatar
My Photos: (14)
Not sure yet, but I'm certain that there is a leaking vacuum fitting on the driver's side the fire wall.
It's complicated, but the signs are there.
The Green Monster
Spencnaz is offline
post #11 of 38 (permalink) Old 08-23-2006, 06:30 PM
The pump's general condition can be determined by checking the timing, Assuming the timing has been constant, a worn pump will make the timing off.
'93 F-250, - most original at 252K miles, rebuilt E4OD 220K miles
Greenie is offline
post #12 of 38 (permalink) Old 08-23-2006, 10:10 PM Thread Starter
Spencnaz's Avatar
My Photos: (14)
Well the truck's running fine, it's this intermittent chugging noise that is driving me crazy.
The truck runs fine, doesn't miss so I know it's not in the valve train or the injection system, it sounds like it's coming from the area of the brake master cylinder and I'm now thinking that it's some sort of intermittent vacuum leak.
The Green Monster
Spencnaz is offline
post #13 of 38 (permalink) Old 08-24-2006, 02:53 PM Thread Starter
Spencnaz's Avatar
My Photos: (14)
Ok I took off the air cleaner and the noise is coming right from the air inlet tube to the turbo, it sounds like a thwock thwock noise.
Engine doesn't miss a beat. I took off the CDR to the intake tube (I have a Hypermax system) to see if maybe the CDR was flapping, no change in sound.
What could be causing this? I sure hope it's not a dropped valve, the noise comes and goes, not something you would expect of a bad valve or broken valve spring.
The Green Monster
Spencnaz is offline
post #14 of 38 (permalink) Old 08-31-2006, 06:23 PM Thread Starter
Spencnaz's Avatar
My Photos: (14)
Ok the truck really lunched this afternoon.
Lots of black smoke, really loud knocking noise, and over heating.
Please tell me this is the injector pump. The truck was running fine the past few weeks. It did this before I put 8 new injectors in. What gives? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Also, looks like there is fuel in the crank case, the engine is over full on oil and I filled it properly last week. The lift pump is brand new as well.
The Green Monster
Spencnaz is offline
post #15 of 38 (permalink) Old 08-31-2006, 10:28 PM
why do you keep going to the pump???? the pump is very simple and almost never makes nosies just produces low fuel psi. or to much ...... almost sounds like a bad injector with a blown head gasket.... injector putting in to much fuel and then blowing the head gasket ,,y i say this is you said black smoke and fuel in the engine .... when you put in the new injectors did you have the psi of the injectors incresed from stock to match your turbo system???
this is just a gess
a man is only as good as his word
2000 f250 XLT, 4x4, PSD,transmedic transmission gresham oregon , auto, XC, 3.73 gears, LB bradford built flatbed, edge juice with attitude, 4"Banks exhaust with Banks jake brake, Banks Trans command, Banks smart lock, Banks big head wastgate, Banks k&n air filter intake kit,ATS ported shroud compressor housing, CFM+ intake manifold,AIH delete,ITP overboost annihilator, Fuel Rail Crossover, Riffraff SS HPX oil cross over tube,Fuel pressure spring settings 66-72 psi, propane injection set at 7psi boost.
1983 f250 6.9, STC, 4X4, 5 speed, LB bradford built flatbed,with BANKS sidewinder turbo kit, BANKS 4" exhaust injectors set at 2150psi
1970 f250 FARM AND RANCH SPECIAL
djbrown is offline
