Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > 6.9L Diesels
Old 07-24-2008, 06:21 AM   #1 (permalink)
how to test injectors
I just got an 86 f250. How do I know if all the cylinders are fireing. It sounds good but it feels a little weaker then my 83 f250. thanks
83 F250 6.9
wellsstyle is offline
Old 07-24-2008, 10:54 AM   #2 (permalink)
arthurgoboom's Avatar
You can either loosen each injector line one at a time while the engine is running to listen for a drop in RPM, or you can use a voltmeter set to millivolts to probe the GP spades (with the GP leads disconnected) to see if they're putting out any voltage. It would be in the 0.5-5.0 millivolt range usually, and all GPs should read relatively even. If you have a reading that is way off, you can swap that glow plug with one from one of the 'normal' cylinders and retest it. If the abnormal reading moves with the GP, you have a bad GP, but if it stays with the cylinder then there is something wrong with the injector in that hole. This test is done once the engine is fully warmed (so it'll start w/o GP harness connected).
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 07-24-2008, 09:21 PM   #3 (permalink)
where can i get a voltmeter. i have a multimeter. will that do it. what should the rpms sound like when its a good or bad injector. thanks
83 F250 6.9
Old 07-24-2008, 09:56 PM   #4 (permalink)
chuckster57's Avatar
My Photos: (6)
Complete description of GP system
If you go to the gallery and search for members photos and look for CDNSARGUY..he has an extensive set of pictures and instructions for our trucks. very good information
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually,
ATS Turbo upgrades, 3" DP with 3" exhaust Magnaflow XL muffler
1997 Jayco fifth wheel 323RKS, Robins 16K dual axis hitch
Apillar pod with: Autometer C2 Series gauges: pyro,trans, boost
Hypermax Cowl induction
Flex-A-Lite 26K tranny cooler w/fan
K&N air filter (we'll see in a million miles)
Tekonsha "prodigy" brake control
chuckster57 is offline
Old 07-25-2008, 12:50 AM   #5 (permalink)
A multimeter with a millivolt scale will do fine. There's no specific RPM you're looking for, you're just listening for a change. The RPM should drop when you loosen the line going to a good injector.
Old 07-25-2008, 09:51 PM   #6 (permalink)
what if the glowplug is dead? than what does the test show ya?
'89 F250 7.3 IDI, c6, 3.55rear, 2wd, 152k miles
DeepRoots is offline
Old 07-25-2008, 10:04 PM   #7 (permalink)
That you need new glowplugs?
Old 07-27-2008, 08:26 AM   #8 (permalink)
The best way to know if your injectors are firing evenly, is to yank them out have have them pop tested. You can make you own tester or take them to a shop and they usually will just do it free or for a very small amount.
I found a VW forum that someone has a picture and a whole writeup using a cheap bottle jack and lots of other odds and ends to make a home made tester.
My Rigs:
86' F-250 XLT Lariat,6.9 Diesel, Extended Cab, 4x4, 4.10's, 8'bed, Push Button Glowplugs, etc...My Truck,My Truck At Christmas,My Album
99' Crown Vic Police Interceptor (P71) w/Steet apperance package, 4.6L, 4R70W, 3.55 Trac-Loc Differential (DK), Total Cloth Interior, New Honeycomb Grill, Black PI Trunk Bezel, Silverstars, 110K,My 99' CVPI Photos
95' Ram 2500 4x4 Laramie SLT, Cummins Powered, 181 DV's, 215 Injectors, #5 Plate Full Forward, Extended Cab, Auto, 3.54's, 8'bed
Fordiesel69 is offline
