Hypermax Pulse Turbo A/R numbers - Diesel Forum - TheDieselStop.com
Old 06-01-2005, 11:24 PM   #1 (permalink)
Hi all.
I posted this on the 7.3 IDI board, but haven't any replies. I'll post here also, and hope for some info.
I just got through installing the older used Hypermax system from Ebay on my '93; man, what a difference! I did purchase new manifold pipes and a new turbo mount from Hypermax, and everything went together fairly well.
I am looking for help from those of you out there runing the current Hypermax Pulse Turbo for the 7.3L IDI. I am looking for the compressor and exhaust turbine A/R numbers for a current production 6.9/7.3 pulse turbocharger. I may have a line on a new in box garrett turbo, that is said to be designed for the Hypermax Pulse system. It has a compressor A/R of .64, and an exhaust turbine A/R of 1.32 with the pulse style "split" or two chamber housing.
Any info would be a big help. It is being held, but I need to let the owner know soon, as there may be another interested party.
Thanks,
Bill
1993 F250 4x4, Extended cab with a 7.3L IDI, 3.55 axles, 5-speed manual, Hypermax Turbo, 3.5" Hypermax exhaust, No soup bowl, a K&N filter, and a RDT. 162,000+ miles and counting.
bgfire is offline   Reply With Quote
Old 06-02-2005, 01:38 PM   #2 (permalink)
My Photos: (23)
Re: Hypermax Pulse Turbo A/R numbers
Bill, contact Huff on this board. He's the guy with the A/R numbers floating around in his head.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, Moose Mister Injectors, Hypermax Turbo, Intercooler, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline   Reply With Quote
Old 06-02-2005, 02:51 PM   #3 (permalink)
Thanks for the reply, Mel.
I went ahead and bought the turbo; got a great price on it. I just found out via email from Hypermax that the current pulse turbo numbers are compressor A/r .7 and turbine A/R 1.15.
The turbo that I am purchasing (Ebay) has a compressor of .64 and a turbine of 1.32. OOPS!
I have posted over on the 7.3 board to see if anybody knows whether that combination can be run safely on a '93 7.3L IDI, and if so, how it will affect turbo preformance.
Thanks,
Bill
