Info on 86 F250 6.9L Needed - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 06-01-2009, 03:02 PM Thread Starter
Hello,
My grandpa-in-law has an 1986 F250 6.9L diesel with a large 3500lb camper that he let us use last weekend. The truck had been sitting for 2-3 years. New tires and batteries, and off we went.
I may be buying the truck off him; excellent condition with 94k original miles, however I do have a few questions/concerns about it.
During pulling, especially with the first tank of gas (first tank of gas was good, put new gas in it before I left), it didn't want to get over 55mph. On the way home, I could just barely touch 70mph (WOT), but it was a struggle. So it seemed to get better the more we drove it. Now, I do NOT need to go that fast, I'm just generally concerned about performance. I only had 3 gears I noticed (automatic); is that normal; am I missing a gear or did these come with 3-speed automatics?
Also, I got about 8.5mpg on my trip (was a 4-hour trip each way on the highway). I know it had a 3500 camper on it, and the camper kills aerodynamics, but what can one normally expect out of these engines? Perhaps a tune-up would bring things up a bit?
Speaking of tune-ups, any recommendations? A general Diesel noob, but have been reading quite a bit. Truck is in great condition; headliner perfect, AC Ice cold, seats in great condition, carpet spotless, so if I can get this motor going well I think I'm set. Note: The engine actually ran great, was just a bit surprised by the lack in power, fuel economy and speed (and that's with some already low expectations). Just want to know if that's below par for the engine, or if I need to reset my expectations!
Thanks!
yoster is offline
post #2 of 7 (permalink) Old 06-01-2009, 06:16 PM
arthurgoboom's Avatar
8.5 mpg on the modern diesel fuels with a slide in camper trying to run 70 isn't too far from normal. The gear ratio in the truck will have a huge effect on MPG, as well as the aero drag from the camper. If you have a 4.10 rearend ratio, 70 mph was probably running the engine at maximum governed speed (3300 RPM). The 4.10 will be the hardest on fuel too. The C6 transmission in it is a 3-speed with no overdrive and no lockup torque converter, so this is also a bad combination for fuel economy.
For comparison, I have a 3.55 rearend and a turbo and only manage about 13 mpg empty. Even with the turbo, mine is no land-missile or anything. They are only 175 hp stock, and that is at 3300 rpm.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Wellman G088 glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
post #3 of 7 (permalink) Old 06-01-2009, 06:34 PM Thread Starter
Ok, that helps a lot. Yes, it was at about 3300 rpm (and it's a 4x4). Note though, I wasn't going that fast for more than 5 minutes on the 4 hour trip. Was usually 55-65mph, unless I came to a hill then it was 35-45mph.
Now, I hear of people on these boards getting 20mph on the highway empty. Is this even attainable with the rear-end that I have? Any tips here?
yoster is offline
post #4 of 7 (permalink) Old 06-02-2009, 10:34 PM
You better drain that GAS out of the tank, before you ruin the engine!
God Bless America!
2014 Chevrolet VOLT
2000 Ford Excursion 4X4 PSD Limited
1986 Ford F250 4x4 Supercab, long bed , 6.9L/AT
2001 "MagneticRed" Corvette Coupe
1979 Pontiac Y84 "Bandit" Trans Am
1988 Lincoln Mark VII LSC
1996 Chevrolet Impala SS Dark Cherry Metalic
1996 Chevrolet Impala SS Black
1995 Buick Roadmaster Sedan
mikeceli is offline
post #5 of 7 (permalink) Old 06-07-2009, 01:21 PM
skunk's Avatar
i just pulled a 8900 pound camper up and down the mts here in vermont for 6 hours got 15-18 mpg. thats on waist oil with acitone. maybe try changing your fuel filter and air filter. or add some fuel conditioner/cleaner. and yes these trucks are as slow as a old style horse and wagons going up hills and will probable blow black smoke too!
Northern Woodland & Tree Care work trucks:
old smokey
- 86 Ford F250 6.9 IH navistar non-turbo idi diesel 4x4 dana 60 rear w/ limited slip, dana 44 front wishbone style, w/ 3.55 gears, C-6 w/ oil coolers, manual walbro frb-13 fuel pump, manual wellman glow plugs, K&N air filter no soup bowl and a homemade cold air intake, 3 inch pipe, class 31 heavy duty tractor truck batterys, lots of real gauges.
big drippy - 86 Ford F350 4 door crew cab, long box, 7.3 Navistar IDI non-turbo diesel, 2wd Dana 70 dually rear with 4.88, c-6 w/coolers.
The Swan - 87 chipmore wood chipper chuck and duck old school style. vm motori sun 4505 3.9 air cooled non-turbo DI 4 cyl diesel, rockford pto.
skunk is offline
post #6 of 7 (permalink) Old 06-11-2009, 12:48 PM
I used to have an 85 f250 6.9 and I could pull 18 mpg, yes it is possible particularly depending on what your altidude is, I would say you should be able to hit 20+
The secret is let it get all of the coolest air that it can. Get rid of the cereal bowl in the air cleaner, upgrade the exhaust to a straight 4" from the manifolds back
It is worth it, being that with economy, comes horsies.
1997 F 350 Single axle, flat bed, 7.3L powerstroke, 161K, 5 speed, Electric Fuel pump (60-80 psi with preporation system & twin filters), Amsoil in motor and Tranny, Amsoil Microfiber air filter, Napa solid clutch, and surely there will be plenty more to add later.
Just finally lost the wheels off of my 85 F250 6.9L. (actually that credit goes to the semi that t-boned and got that done
crazycooter is offline
post #7 of 7 (permalink) Old 06-17-2009, 06:42 PM
CowKiller's Avatar
My Photos: (12)
i got 25 mpg in mine on a 9 hr trip at 75 mph average. truck had 3.54 gears, 35 inch tall tires and a stick(4 speed no overdrive).
iwould change all the filters and as stated open up the intake/exhaust.
PLAY TRUCK
1986 F250 6.9,ATS turbo, np435, BW1356, hp 60,welded up sterling 10.25.
converted from 2wd to 4x4
sittin on 36x12.5 goodyears
GETTING CONVERTED TO SHORTBED AS WE SPEAK!
TOW RIG
2002 gmc 2500hd 6.6 duramax 5 speed allison
4x4 extened cab.
2000 F550 Lube Truck (Work Truck)
Certified PA Inspection Mechanic
i'd rather be 6.9'n than cummin or strokin'!
CowKiller is offline
