Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > 6.9L Diesels
Old 08-04-2008, 05:08 PM   #1 (permalink)
Injector/Injector line leak.
I decided to fix "leaky" my 84 ford and it has a couple of leaks right where the hard fuel line screws on the injector, Is there a o ring or some kind of seal in that area that can be replaced?
magking1971 is offline
Old 08-04-2008, 06:07 PM   #2 (permalink)
chuckster57's Avatar
Are you sure it's not leaking from the return lines? that's the plastic type caps over the injectors with a fuel line connecting them all to the IP and tank return. There is an "O" ring at the top and bottom of the "cap" and they are known for leaking. I replaced mine. Best to buy the complete set and change them all. It is available from one of the vendors here or at the major auto parts chains. When I did mine I used vasoline on the "o" rings so that they will slide and not "roll" out and leak.
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually,
1997 Jayco fifth wheel 323 RKS, Robins 16K dual axis hitch
Apillar pod with: Autometer C2 Series gauges: pyro,trans, boost
Hypermax Cowl induction, Flex-A-Lite 26K tranny cooler w/fan
K&N air filter (we'll see in a million miles)
Tekonsha "prodigy" brake control
Train Horns: Pictures here
chuckster57 is offline
Old 08-05-2008, 10:08 AM   #3 (permalink)
Joe Mc's Avatar
My Photos: (27)
No o-rings, just a metal to metal flare. Your lines may have cracked, this often happens when people remove the line clamps.
Click Here to see the clamps.
Click here for a place to buy the lines and clamps.
Red 86 F250 Supercab XLT, Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Remote lube TOB.
BOOB man - Brotherhood of Oil Burners
Joe Mc is offline
