If anyone knows of a previous post regarding new IP pump to engine timing/installation, would you please let me know, or fwd it along.
I just purchased a new IP (w/ housing attached) and already have this 6.9L opened up.
Thank you for any assistance.
Opened up? Did you remove or even loosen the 2 big bolts on the IP gear cover?
Because you Never want to do that unless you are doing a total rebuild. Of course unless your a diesel mechanic you don't want to turn a bolt until you have done some reading here.
__________________ Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
Triple A-pillar pod: Isspro EV voltage and oil-pressure gauges.
Road-Watch System (Air and road-surface temperature gauge).
Chicken Lights Gone.
Since the IP is usually only good for about 100,000 miles and is under $500, why install a used one? With the gear and cover attached your's came off a used engine probably by someone looking for a fast buck. Why else would they ship you the gear and cover, that just raises the shipping cost.
