IP Problems - Diesel Forum - TheDieselStop.com
Old 11-21-2005, 12:12 PM   #1 (permalink)
IP Problems
I think I am having issues with my IP. Symptoms are that a week ago I was driving over to a friend's, when suddenly the truck had no power going up hills; it would stall frequently, especially when under load. At the time I thought it was a fuel issue, because I still had a bunch of biodiesel in the tank and it was cold that day.
Today, it was much warmer (and I added 20% D1 to the tank), but I started seeing similar symptoms when driving (turned around and took the car instead). It's not likely a fuel issue now with the thinned down fuel, so I am looking for an air leak or IP problem.
From memory, I recall the trick of replacing the return line with clear plastic to see if there are air bubbles in there. I also sortof recall taking to top cap off the IP to see if there is plastic floating around in there, but I thought there was some special way to reassemble the pump after doing this to avaiod a run-away problem.
Anyone recall the details of openning up the IP and putting it back together?
Any other suggested areas to look at for this problem?
TIA
86 F250 4x4 X-Cab ZF5 4.11
steve777 is offline
Old 11-21-2005, 07:42 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Re: IP Problems
Check your email in a while........... When was the filter last replaced. You can divert the IP return fuel into a clean margerine container your looking for black specs. Does the blocked filter light come on or even work.
Proud Canadian BOOB man too!!
cdnsarguy is offline
