Leaking Glow Plug Control Swith??? - Diesel Forum - TheDieselStop.com
Old 12-02-2009, 09:14 PM   #1 (permalink)
Cool Leaking Glow Plug Control Swith???
Hello All,
I have a new leak that appears to be coming from either the rear of the valley pan or what appears to be the "control switch" that threads into the block just behind the CDR. BTW, I have a van, so everything is EASY to access in the rear (but horrible in the middle!).
Does the control switch contact oil on the inside of the block? If so, that might explain the leak and I can just replace the rubber washer on the switch. If it doesn't then the nightmare begins since I assume I'll have to remove the valley pan which includes removing the IP (?).
Shoot, if I gotta do THAT then I may as well get new head gaskets and do the whole top end, eh? Please let me know your thoughts and I'll try to get pics of the leak ASAP.
THANKS DIESEL BRUTHAS!
1987 E-350 6.9L N/A
C-6 w/Dana 70 3.54
43K original miles & NO mods
Las Vegas, NV
InTheDogHouse is offline
Old 12-02-2009, 09:26 PM   #2 (permalink)
chuckster57's Avatar
If your leaking oil and it is coming from that "Dome" looking thing that threads into the block: that's the oil pressure sending unit. Cheap fix.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline
Old 12-03-2009, 12:12 AM   #3 (permalink)
Oil Pressure Sending Unit?
Is THIS the Oil Pressure Sending Unit? And if so, can I replace it with a "screw in" aftermarket that will read actual pressure? Thanks!
1987 E-350 6.9L N/A
C-6 w/Dana 70 3.54
Las Vegas, NV
Old 12-03-2009, 10:25 AM   #4 (permalink)
Joe Mc's Avatar
My Photos: (39)
You can use the after-market sender if you also install an after-market gauge.
That is your stock oil sender.
Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW
BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
Triple A-pillar pod: Isspro EV voltage and oil-pressure gauges.
Road-Watch System (Air and road-surface temperature gauge).
Chicken Lights Gone.
Joe Mc is offline
Old 12-03-2009, 11:14 AM   #5 (permalink)
Like Joe Mc said..You can run an aftermarket pressure gauge. There are the electric styles and the mechanical styles that use a thin tube. Your pressures will be about 10-12 PSI @ idle and 35-40 @ cruising when fully warmed up. So if you do go with an aftermarket, make sure it reads 0-60 not 0-100 as it may not register @ idle.
Old 12-03-2009, 03:54 PM   #6 (permalink)
Joe Mc's Avatar
My Photos: (39)
Chuckster57, 0-60 might be a little low, I have a 0-80 and I have seen about 78 on a below zero start.
Joe Mc is offline
Old 12-04-2009, 01:41 AM   #7 (permalink)
Resolved
Thanks all, got everything resolved. Found out how to convert the oil pressure "idiot" gauge to an ACTUAL measuring guage via a new sender unit from an older year Ford (http://www.rowand.net/Shop/Tech/Ford...reGaugeFix.htm) and the removal of a 20ohm resistor.
Found the part at Autozone for $10 bucks (1981 F150 any-engine), removed the 20ohm resistor and restored the old guage it to it's originally designed purpose - to measure oil pressure! Also put new teflon tape on all the threads and now have NO LEAK with a REAL GAUGE to boot. Happy as a clam.
P.S. Of course I can't see actual oil pressure numbers with the stock guage, but I know from other posts where on the guage equals what pressure and know what to watch for.
1987 E-350 6.9L N/A
C-6 w/Dana 70 3.54
Las Vegas, NV
Old 12-05-2009, 09:25 AM   #8 (permalink)
Joe Mc's Avatar
My Photos: (39)
Nice find!
Try this link: Ford Oil Pressure Gauge Fix
Joe Mc is offline
Old 12-05-2009, 09:39 AM   #9 (permalink)
Now that I take a look at mine, it is 0-100. I haven't been in my truck for a while... But It is 270 degree sweep so I can see small changes. THAT'S what I meant to stress. Oh well his problem is fixed and that's what matters.
Old 12-06-2009, 12:33 AM   #10 (permalink)
Well, I may have a cool new oil pressure sending unit, but I still have a terrible oil leak (6 inch puddle in 1 day) coming from what appears to be the rear-center of the valley pan.
At first I thought it was the oil pressure sending unit, but have a new one with teflon tape and rubber O-ring seals that aren't leaking. Any other possibilities besides the valley pan? It would really SUCK if that had suddenly developed a terrible leak. Thanks all.
1987 E-350 6.9L N/A
C-6 w/Dana 70 3.54
Las Vegas, NV
