Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > 6.9L Diesels
Old 08-03-2008, 10:53 PM   #1 (permalink)
Question Loss of turbo pressure, loss of power
Ok, here it one for you all. Truck runs fine, starts, rolls, gets up to speed, sounds ok, everything. But put in under a load, gutless. I can't seem to get more than 4psi of boost from the ATS turbo where I was getting 7 to 9 psi. I'm lucky to go 55 mph and feel like crap doing 35 mph up hills. The loss of power came with a interesting pinging/whine that turned into the same noise you would hear with an exhaust leak from the manifold. Looked the motor over and could not see any evidance of exhaust leak. The noise seems to be coming from the upper portion of the motor, right side. Could injectors cause any of this???
Just incase, 1984 f250 6.9 with ATS turbo, Racor heated filter, pretty much stock.
Andy
Andy
1984 Ford F250 6.9 ATS Turbo, C-6, Racor Filter/Water Sep Mod, Firestone RideRites air system.
lowblues is offline
Old 08-07-2008, 10:21 AM   #2 (permalink)
arthurgoboom's Avatar
Do you think it's possible the turbo ingested something? That does a number on the turbine wheel (I know) and your boost levels will be reduced.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 08-07-2008, 02:46 PM   #3 (permalink)
hesutton's Avatar
My Photos: (30)
My guess would be an exhaust leak or your turbo is dead/dieing. The horrid noise could be your compressor or turbine wheel kissing their respective housings. I'd pull the intake off and have a look and a feel of the compressor side of things. Also, have a good look for leaks anywhere in the system.
Heath
1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
1983 F250 4x4 5.0L with C6. 340,000+ miles.
7.3 Project Pictures
Webshots Project 7.3 Gallery
DYNO YOUR IDI AT THE 2009 RALLY
hesutton is offline
Old 10-11-2008, 01:27 PM   #4 (permalink)
Got the prblem fixed. Thanks guys. It was a loss of exhaust as one of the right exhaust manifold bolts actually fell ogg and another was loose. New bolt and tightened all the others, good as new. Also just reciently had the IP rebuilt. Winter is on the way and it seems like the truck is ready for it.
Andy
lowblues is offline
