Lots of leaks
While looking at the loose right inner tie rod on my truck last night, I noticed almost everything is wet(oily). I know it has a power steering leak, but what else could be leaking? Should I get under it and tighten everything up?
Also, it's got a real slight coolant leak, I think where the upper raidator hose connects to the radiator. Is there a special stop leak for diesels or can I use anything? I've only added coolant to it once since I got it in May.
Would like to have a 3.54 geared rearend if anyone close to southwest Missouri would like to trade for a 4.10 geared rearend(Dana 60)
Trevor in MO
85 F250 extended cab 2WD, 6.9, C6, 4.10, no soup bowl, "ram-air", Pioneer CD player, 4 Bose Speakers from an H2 Hummer, Polished Aluminum Outlaw wheels
