Mobil Delvac 15W40 - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 03-05-2005, 07:52 PM Thread Starter
Spencnaz's Avatar
My Photos: (14)
Mobil Delvac 15W40
Have any of you guys had experience with Delvac 15W40?
It's getting about time to change the oil here and I want to get another opinion of this oil.
My friend has a PowerStroke and has driven trucks for years. I've just not had any experience with this particular brand, primarily Rotella and Delo (ugh I hate that oil).
Also have you guys ever done the PowerStroke oil filter swap on your 6.9? You get an added 1/3rd or about of extra filter when you put one of those on.
Any suggestion would help.
Spencnaz
The Green Monster
: 2001 F250 Powerstroke, 2WD, ZF6 transmission. Bully Dog GT Tuner set in tow mode. MotorSilk boric oxide added to engine, transmission and diff. Showing 30mpg on the freeway running home brew biodiesel. NTZ 1/2 Micron bypass oil filter. Dieselsite coolant filter. 4" open turbo back exhaust. Ford AIS intake. Donaldson ELF7405 oil filter. Caterpillar ELC next on the list.
Spencnaz is offline
post #2 of 14 (permalink) Old 03-05-2005, 08:13 PM
My Photos: (23)
Re: Mobil Delvac 15W40
can't say anything about the delvac, as i've always run amsoil 15w40. but most guys here & upstairs seem to like the rotella. maybe spring for the synthetic blend?
click here for a recent thread about the filter - found it with a quick search of the archives, BTW... i run a powderstroke size on my 7.3 these days, & apparently the motorcraft FL1995 is the part # and will fit the 6.9 as well.
Frank
Unofficial
man (unofficial BUTT division: brotherhood of un-turboed trucks)
meet
, my 1992 International 3/4 ton pickup wrapped in a Ford skin: 2wd, LWB, N/A 7.3, ZF5, 3.55s. 249k miles.
Amsoil bypass & AF. 3" true duals. no soup for me. 'ghetto' fresh air. Baja block drains. bottle broke. slobber tube. true dual 3" straight pipes. now a TRUE oil burner - she's drinking 15% Bunker Fuel (WMO).
soulpatchfr is offline
post #3 of 14 (permalink) Old 03-05-2005, 08:17 PM
delvac 1300 is all i and all of my customers use been using it since i worked at ups and that was good enough for them . and i think they have just about the biggest fleet anywhere.
94 f450 superduty, 7.3 idi, factory turbo, e4od trans, 5.13 gears, 14000lbs + across the scales every day of the week, 11'redding utility body, 3 cyl kubota diesel(tied in to truck cooling system)for air compressor , front bumper is 8"x8" square (air tank), 4 group 31s batteries mounted to frame under cab,2 straight stainless pipes pokin up in the air and no muffler(sounds great) now runnin on 100% wvo
2ND IDI
93 F250 XLT 2WD 7.3 IDI E4OD ALL STOCK MORRISON UTILITY BODY 10 horse yanmar diesel on the compressor, batteries relocated to under the the cab on the frame
magyver is offline
post #4 of 14 (permalink) Old 03-05-2005, 08:21 PM Thread Starter
Spencnaz's Avatar
My Photos: (14)
That's good to hear from a fleet mechanic. I know I can get Delvac for cheap around here in Seattle.
Now if I could only get lower diesel fuel prices, gotta start making biodiesel...... [img]/ubbthreads/images/graemlins/grin.gif[/img]
The Green Monster
Spencnaz is offline
post #5 of 14 (permalink) Old 03-05-2005, 08:33 PM
I've been running the FL1995 2qt Stroke filter on mine for a little over 3 years. I also read that it has better filtration than the 1qt Fl784.
Rick
86 F250 N/A 4WD w/HomeGrown Propane, Poly Spring/Body Bushings, PushButton GP Controller, 3.55L rear, Goodyear WorkHorse II XTRA Boots, 248k miles, Rotella 5-40W Synthetic
Rick_Hipp is offline
post #6 of 14 (permalink) Old 03-05-2005, 08:48 PM
I couldn't get it to fit on my 2WD automatic truck. I hear it will work on any other type of 6.9, i.e 4X4 or T19/ZF5. It really looks like it should work on tyhe 2WD C6 model but I just can't get it to. Wish I could. can't tell the original poster about the Delvac, use Shell Rotella T here.
J.D.
J.D.'s Fords: 1986 F-250 6.9 diesel Solid State Glow Plug System 3.55 gears C-6 2WD 178,960 miles.... it still runs pretty good!
Wishlist H-max turbo, T19 tranny,
1989 Ford Ranger ga$$er, non runner, soon to be donated or scrapped!
jdkline is offline
post #7 of 14 (permalink) Old 03-06-2005, 07:01 AM
I run Rotella 15w40 and use a Powerstroke filter. (FL1995)No problems here. I also have a 2wd F250 w/ C6 automatic.
John
1987 F250 Extended Cab, 2wd, Lariat, 6.9, C6, 3.55 limited slip, new IP, 7.3 fuel filter/water seperator, slight lift kit, Transfer Flow fuel filler necks, 2 trans coolers, auxillary trans filter, rocking stereo, headlight relay mod, back-up light relay mod, straight-piped 3" exhaust into dual 2.5" tailpipes with 3.5" tips, new Motorcraft batteries
160k87F250 is offline
post #8 of 14 (permalink) Old 03-06-2005, 10:54 AM
John & JD, my son's Super Cab 2wd has no problem using a Stroker filter but I use the Rotella Synthetic in both of mine. I'm rewoking the 6.9 in my nephews to sale now but will use Delo, Delvac, or Rotella dino in it. The future owner can use what he prefers.
Rick
post #9 of 14 (permalink) Old 03-06-2005, 11:44 AM
i use the delvac and have had good results, i like it alot. i was talking to my parts guy about going to something other than rotella and he told me about this oil. he said thathe used to drive bug rigs for the second largest company in the world and they used it in all of their diesels and only changed them about 15-20,000 miles, i said ok ill take a case! although i would never run my oil that long.
-Jeremy ROooster!
American by birth, Southern by the grace of God!
1991 F250 7.3l 200XXX extended cab long bed. 3.55's REDNECKED OUT!! 295/75/16 Bfg All Terrains 16 in billet rims. New front brake pads and rotors, rear shoes, glow plug controller, glow plugs, return line kit duralast batteries, mitubishi off set gear redution starter, altenator, valve cover seals, holley red pump,new injector pump, soon to be new injectors, new vacum pump. Removed soup bowl and drilled holes in air intake.
R0oster06 is offline
post #10 of 14 (permalink) Old 03-06-2005, 08:49 PM
Yeah, well, you have to consider that OTR drivers are almost always at highway speeds, just cruising right in the engine's preferred opearting range, less wear occurs here and they also have larger oil sumps and better filtration. Does anyone know why my truck o=won't accept teh FL-1995 or if I just did something wrong. Thanks a lot,
J.D.
jdkline is offline
post #11 of 14 (permalink) Old 03-06-2005, 09:09 PM
My Photos: (23)
i'm confused, JD...
what's not fitting? thread size? maybe you got a bad part?
physical size of it? i've never been under anyone's IDI but mine - but the OF is so far forward, i just can't see how the tranny would matter?
EDIT!!! forgot to mention - there's a pic in my gallery of a BG drains the clearly shows my OF.
post #12 of 14 (permalink) Old 03-06-2005, 09:43 PM
JD,
Sometimes I have a little trouble starting the FL1995. It kind of sits at an angle and it's a little tight near the oil pan, but it does fit. I've been using it since around 2001 when I learned it would fit. Maybe you got a bad filter? It should work.
John
post #13 of 14 (permalink) Old 03-06-2005, 11:15 PM
John, I tried two different ones at many angles. i wish it would work. It would be nice to ahve the extra oil and better filtration. I tried it on my friend's 1984 2WD reg cab dually w/ C6 also so I figured it was 2WD C6 models only that it wouldn't work on. Maybe I'll try yet again. SOme of you all might remember Danweis, who for some odd reason couldn't get any filter but a Fram on his truck, not ebven the stocker FL-784!! So I don't know what teh deal is, it looks like it should fit, the threads are the same, it just won't start, and the 784 fits like a glove,
J.D.
jdkline is offline
post #14 of 14 (permalink) Old 03-07-2005, 02:03 PM
beretzs's Avatar
My Photos: (13)
I have been using the FL1995 on my truck since I have owned it and shell Rotella 15/40, the only thing I am changing is going to swap to synthetic 5/40 to see if I get a little better hot oil pressure, other than that, maybe a little more mileage out of my oil. Scotty
Semper Fi
Scott Beretz
2006 Dodge Megacab 4x4, Cummins, 6 Speed, Airbags, Quadzilla Commander, XZillaraider 2, 285/75R17 Toyo OC AT's
Pulls a: 3814SS Keystone Raptor Toyhauler w/Quads
beretzs is offline
