Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > 6.9L Diesels
Old 08-10-2008, 09:58 PM   #1 (permalink)
WhiteGardens's Avatar
My new, C-6 issues.
I know, that's what you guys are all thinking especially for anyone who has been keeping track of my C-6 posts.
So this is the second tranny from what used to be Accurate, now call EX transmissions. It was working great, shifting good, downshifting when needed to, upshifting and holding 3rd very well.
Now, sometimes I put it into reverse, and it won't engage, I put it into drive and it won't engage. I have to put it into reverse and throttle it a little in order to get it to engage. Almost like it's not building enough pressure to engage the gears.
Any thoughts on my problem before I call for another transmission.
THE BLUE BOMBER!
87 ford f-350 cab-chassis dually. 2wd, 6.9, 3 speed C-6. 3 leaf helper springs, 11,000 gvwr, pintle/ball hitch, 6 pin round trailer connector (unhooked currently). Rear generic truck stop lights. Twin I beam front end with coil springs. Plow lights and switch to go from headlights to plow lights. 8.5 foot meyer diamond plow with central hydrolics. 8 foot rugby dump bed. 167,000 miles and still strong.
WhiteGardens is offline
Old 08-12-2008, 03:31 PM   #2 (permalink)
jabink89's Avatar
im sorry to hear that buddy, i just hope when i pick up my truck friday with my new c6 i wont be in the same boat
jabink89
1986 f250 Lariat 4x4 6.9L c6 auto/285-75-16's/ brand new viper red paint with my own custom interior viper red and black to match body/front flare out fenders to match newer body style bed from a 95 (custom)
my current project
1985 f250 4x4 in the process of getting her ready for a 12 valve cummins swap.
jabink89 is offline
Old 08-14-2008, 05:40 PM   #3 (permalink)
I wonder if it's a problem with the valve body.
My personal opinion is a T-19/ZF-5 swap.
Rednecks have more fun!
1992 F350 CC LB 5.8L 5-speed 4.10 L/S. Stock
92F350CC is offline
Old 08-14-2008, 06:23 PM   #4 (permalink)
so long as whoever built the trans--has no leaks in the seals, sealing rings, or gaskets--its the valve body-----as ive seen a few of these messed up---make sure theres no oil present in the vac hose where it hooks to the mod--with engine off--if so--modulator has a hole in it---
94_turbo is offline
Old 08-15-2008, 01:19 AM   #5 (permalink)
I called the tranny company. The rep said that one of the valves is probably sticking. He suggested going to NAPA and getting an additive for it that they recomend. I can't remember the name, but it comes in three colors, red, blue, and black.
If I can't get this tranny to work, then I might pull it, have a shop inspect clearences/parts, and put a new valve bady in it.
I don't want to deal with this company any more.
Thanks for all the replies.
THE BLUE BOMBER!
Old 08-15-2008, 11:21 AM   #6 (permalink)
arthurgoboom's Avatar
FWIW, you could remove the valve body yourself, it can be taken out without removing the transmission from the truck. You can take the valve/spring covers off one at a time and take the valves out, clean them really well, lube with new ATF, and put back together. I did this to mine, I spent maybe an hour with the valve body on the bench.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 08-16-2008, 07:47 AM   #7 (permalink)
Thanks Arthur .
I was pretty sure I could take the body off pretty easily. If I have any more problems then I at least drop it out of there and have a look at it. I'm going to see what it does in the next month or so before winter. It needs to work if I'm going to plow, I can't afford to be trying to get it into gear when pushing snow.
THE BLUE BOMBER!
Old 08-16-2008, 02:45 PM   #8 (permalink)
The Saga continues....
Wow.... well, hope it's something easy.
A C3 or C4 tranny of mine right now is taking a while to engage in reverse. But I think it was filled too much w/ fluid...
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Kaliburz is online now
