need head removal or rebuild pictures??!! suggestions and recomendations - Diesel Forum - TheDieselStop.com
Old 11-29-2005, 11:34 AM   #1 (permalink)
if anyone has pics of their rebuild/head replacement, i would appreciate it if you could link me to them. basicaly i am looking for detailed pics and explanations of how you did it, or what you would do differently,what worked and what did not work? or if you know of a post or thread that has this info or these pics.
i'm just trying to fill my head with as much info as possible before i remove the heads. i've already got the belt driven accesories off the front of the engine, the y-pipe detatched from the exdhaust manifolds, and it has been drained of coolant and oil.
i still have not ruled out removing the motor to do the head gaskets. nor have i ruled out having to replace pistons or rings or whatever else. what should i look for when i remove the heads? how would i know if i have a bent rod or bad bearing? what changes should i make while i'm inside the motor, if any?
sorry about all the ?????? i'm just trying to cover all my bases here.
thanks.
rob
83 f250 bw t19 , bw 1345
creteman is offline
Old 11-29-2005, 12:24 PM   #2 (permalink)
Re: need head removal or rebuild pictures??!! suggestions and recomendations
Check out Mel's Head Gasket Article. Start to finish + adding a turbo.
Rick
86 F250 N/A 4WD w/HomeGrown Propane, Poly Spring/Body Bushings, PushButton GP Controller, 3.55L rear, Goodyear WorkHorse II XTRA Boots, 248k miles, Rotella 5-40W Synthetic
Rick_Hipp is offline
Old 11-29-2005, 03:08 PM   #3 (permalink)
If you have the motor out the open up the oil pan and check for coolant and/or rust. I would at least take it apart and have the blocked "dipped" which would clean out the passages (oil/water) from years of use. Other than visual inspection on the rods for bent ones, you can lay them down on a clean flat surface and see if they rock (on the side) or lay them flat, carefully draw an outline with a pencil and place each rod into the outline checking to see if they match up. Look at the crank to see if you have any burn marks on the bearing journals and/or the block journals. There are more ways but these seem to be the easiest for me. I would definitely replace the seals and bearings (their cheap) if you go that far. Definately check your cylinders for roundness and wear and clean up accordingly. You may have to sleeve some of them. Basically your inspection of the short block will determine how far you should go. Ask a friend to come by for an evaluation if your not sure. Put some money away cause you'll need it, [img]/ubbthreads/images/graemlins/depressed.gif[/img] but there is nothing more satisfying than hearing your engine purrr after you rebuild it..
Ahhhh yess....... memories...... [img]/ubbthreads/images/graemlins/grin.gif[/img]
85 Ford F-250 4X4 6.9 diesel - R134 New AC/New rear-end/New Transfer Case & Clutch/New ignition (yes all of it)/New block heater (works great)/New injectors/bypassed water seperator on firewall - Owned this since 1989 :-) T-19 4spd-No Ovedrive 15MPG ave @ 67MPH - 2nd owner
jmjames is offline
Old 11-29-2005, 08:13 PM   #4 (permalink)
Most important advice I can give is to back off the head bolts in small increments ( like 1/4 to 1/2 turn) in the reverse of the torque sequence used to install them.
There is enough resilience in that old head gasket that improper unbolting will certainly crack those heads.
MSFII is offline
Old 11-30-2005, 01:49 PM   #5 (permalink)
thanks for the replies.
riphip, yes i have seen mels hg article, damn near been like a bible the last couple of days.
jeff43, i still have not decided to pull engine out or not, but i better figure it out soon because the boss is coming over in a bit to tow it to his shop so i can have a place to work on it. i really need to fix the oil pan leak, so i'm kinda leanin towards pullin it out. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
soilsengineer, with my luck i probably already have a cracked head, but i am going to be sure and follow the sequence just incase the IDI gods were watching over me. [img]/ubbthreads/images/graemlins/wink.gif[/img]
anybody else ?
anybody got pictures of engine being pulled out?
thanks.
rob
creteman is offline
Old 11-30-2005, 10:21 PM   #6 (permalink)
having just pulled an engine, I can say I was glad I'd removed the radiator and fan. the room that opened up was nice and probably necessary.
86 f-250 6.9, c6 4x4 cracked windshield, bypassed water separator, no fuel gauge readings, front and rear end no idea looking for a good used 6.9 or 7.3 engine(I think I have one now)
julianshulman is offline
Old 12-01-2005, 02:48 PM   #7 (permalink)
My Photos: (23)
If you look through my Moosestang album, you'll see a few pics of engine disembodiement. However, given the experience so far of converting the Bronco, I'd recommend that you pull the front clip. Not as bad a job as it sounds, and you'll be able to do so things that will make the repair all that much more enjoyable. Not only that, but your radiator core support and front clip mounts are surely in need of attention. If you pull the front clip, take the oil filter and starter off, you can pull the whole drivetrain in one shot.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, Moose Mister Injectors, Hypermax Turbo, Intercooler, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 12-01-2005, 07:31 PM   #8 (permalink)
Not totally completed yet, and it's a 7.3, but has lots of hi-res pics:
HG Removal Write Up
Ryan
1988 F250 Supercab, 4x4, 7.3 IDI, C6 Auto, 147K miles
Banks Sidewinder non-wastegated Turbo, Stage 1 Injectors, and Pyro, Boost and Water guages.
My Gallery
analog is offline
Old 12-01-2005, 10:38 PM   #9 (permalink)
h2odrx's Avatar
great job! i like the pics it helped me see what i don't have on my truck, and if i ever have to do it what will need to be done! that is the way i do it take lots of pics because i never seem to get it back like it should!
Remember, we aren't eating this stuff, we're turning it into diesel fuel. Your truck only cares about viscosity, acidity, and BTUs. Nothing else. -unknown?
NC State law defines biodiesel as ''any fuel or mixture of fuels derived in whole or in part from agricultural products or animal fats or wastes from these products or fats.''
Exemptions from the excise tax
h2odrx is offline
Old 12-02-2005, 08:40 AM   #10 (permalink)
My Photos: (23)
HG Removal Write Up
Wow! You really made a major project out of that one! [img]/ubbthreads/images/graemlins/grin.gif[/img] Nice job with the pictures. Much better than mine. Of course, I didn't own a digital camera at the time. As for the cork gasket, I'd have told you (or maybe I did) I'd never use Cork! Ouch.
- Mel
agnem is offline
Old 12-02-2005, 07:28 PM   #11 (permalink)
Thank you very much for linking me to your hg write up. I had seen this before but couldn't find it again. It was very helpful. I just pulled the heads off my 6.9 today. Will try to post pics later.
Thanks.
Rob
creteman is offline
Old 12-03-2005, 03:09 AM   #12 (permalink)
Analog, taht is very thorough. I'm duly impressed,
J.D.
J.D.'s Fords: 1986 F-250 6.9 diesel Solid State Glow Plug System 3.55 gears C-6 2WD 178,960 miles.... it still runs pretty good!
Wishlist H-max turbo, T19 tranny,
1989 Ford Ranger ga$$er, non runner, soon to be donated or scrapped!
jdkline is offline
Old 12-03-2005, 09:09 AM   #13 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Ryan very nice work.....I will be sending that writeup all over the world with Mel's turbo install.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 12-05-2005, 05:24 PM   #14 (permalink)
Thx guys.. now that I have people actually reading it, guess I'd better get it finished.
Mel, yeah, the cork gasket was a major goof.. oh well, no major harm done just a few, ok a LOT, more curse words added to the garage's ears.
Ryan
My Gallery
analog is offline
