These trucks have a stock lift pump feeding the IP(Injection Pump), the stock one is mechanical and is located low near the front of the passenger side of the engine.
You shouldn't need to bleed the injector lines, keep it floored while cranking to get the IP moving the max amount of fuel.
Red 86 F250 Supercab XLT, Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Remote lube TOB.
BOOB man - Brotherhood of Oil Burners
