Oil capacity? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 06-24-2008, 10:16 PM Thread Starter
CDX825's Avatar
My Photos: (11)
Send a message via AIM to CDX825 Send a message via Yahoo to CDX825
Oil capacity?
Ok time to change the oil in the truck. Was wondering how much oil Im going to need. My service manual says 10 quarts and 11 with the filter. I ended up geting the power stroke filter as you guys recomend and that gives me an extra quart. So then I should be at an even 12 right? Thanks again guys! Justin
-Justin
1984 F250 6.9 C6 2WD Push Button Glow plugs, No Soup bowl. Wix 33439 Water Separator, Carter P4594 fuel pump, Custom 3" Exhaust, NTZ Oil Bypass Filter, VDO Vision water temp gauge, ISSPRO EV Pyro
CDX825 is offline
post #2 of 8 (permalink) Old 06-24-2008, 10:24 PM
NCheek's Avatar
I use the powerstroke filter and put 10 qts (stock with filter I assumed...) and 1 qt extra for the larger powerstroke filter. Now you make me want to go outside and check my manual...
-Nick
1986 F-250 2WD, Regular Cab, LWB, 6.9, T-19, Sterling 10.25", open 3.55's, XLT Lariat, Texas Sesquicentennial Limited Edition, No Restrictor Plate, manually switched high idle/advanced timing, and an awesome custom shift knob thanks to Bruce Roosa / Koolknobs.
279,000 miles and counting, hoping for a US Gear OD and a Hypermax Turbocharger one day.
My first truck:
1982 F-250 4WD, Extended Cab, LWB, 5.8, C6 to T-19 swap, BW 1345, Dana 44 TTB/Dana 60 Semi Floater, open 3.55's. About four different colors (not counting rust), currently on loan to my little brother. Maybe one day it can be home to a 6.9L too.
Work Truck:
1992 F-700 Flatbed w/ dump, 7.0L BIG BLOCK GASSER, 5-speed trans (Clark?), 26,000 lb GVWR. Rides like a tank
NCheek is offline
post #3 of 8 (permalink) Old 06-24-2008, 10:27 PM
chuckster57's Avatar
I always buy 3 gal. jugs (12 qts.) and keep the extra for "top off" between oil changes
Train Horns:
PM please not visitor message
chuckster57 is offline
post #4 of 8 (permalink) Old 06-24-2008, 10:30 PM
NCheek's Avatar
According to my "1986 Light Truck Owner Guide Supplement for the 6.9 Liter Diesel Engine" says 10 quarts with a note that says, "includes one quart for filter replacement."
Didn't mean to come across as preachy, but I would go with 11 quarts.
-Nick
My first truck:
Work Truck:
NCheek is offline
post #5 of 8 (permalink) Old 06-24-2008, 10:33 PM
NCheek's Avatar
My local wal-mart carries rotella 15w-40 in 2.5 gal jugs (10 qts.) so its nice to go in and buy one big jug, one quart jug and a filter.
-Nick
My first truck:
Work Truck:
NCheek is offline
post #6 of 8 (permalink) Old 06-24-2008, 10:36 PM
Next time I go to Wally-world
I'll have to look closer. I normally use my parts store (have account..ie discount) .
Train Horns:
post #7 of 8 (permalink) Old 06-24-2008, 11:26 PM Thread Starter
CDX825's Avatar
My Photos: (11)
Yeah thanks guys. I bought a service manual for the engine off of ebay awhile back its and original IH manual that a bus garage had up for sale so I snagged it up thinking it may come in handy. It says Crankcase capcity (without Filter) 10 quarts and then below that it says Crankcase capacity (With Filter) 11 quarts. So if that powerstroke filter holds an extra quart we have 12. I think thats right anyway but im not positive when it comes to the powerstroke filter as Im still a learning. I am going to end up picking the oil up from wally world though. I checked the other day and the biggest container they have of rotella is a gallon. I figured three of those and I should be good to go. Thanks again guys!!!
-Justin
CDX825 is offline
post #8 of 8 (permalink) Old 06-25-2008, 12:47 AM
NCheek's Avatar
It's very possible that the IH configuration of the 6.9 used in busses and trucks had a different oil pan. I would fill up with 11 qts using the PSD filter, get the engine up to operating temperature and the check the oil level. You don't really want to overfill the crankcase and suck any more oil through the CDR than you already have to...
-Nick
My first truck:
Work Truck:
NCheek is offline
