oil pressure question - Diesel Forum - TheDieselStop.com
Old 11-22-2005, 11:29 PM   #1 (permalink)
I've noticed when getting off the highway, my oil pressure drops to around 5-10 psi. It doesn't matter if it's hot or cold out It never has any problems and as soon as you touch the throttle, it jumps back up. Is there a need for concern? Should I invest in an oil cooler? I run Rotella 15W-40 and a Motorcraft filter, if that makes any difference.
Also, I drive about 125 miles to work and back per week, is it normal for me to add a quart of oil per week?
Trevor in MO
85 F250 extended cab 2WD, 6.9, C6, 4.10, no soup bowl, "ram-air", Pioneer CD player, 4 Bose Speakers from an H2 Hummer, Polished Aluminum Outlaw wheels
redbeard85 is offline
Old 11-23-2005, 12:31 AM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Re: oil pressure question
If your engine is returning to idle 10 psi is allowed, at 3000rpm it should be 40-70. The 6.9 is known to be an oil user but over filling can cause an excess.....
A friend from Ford posted this........
DieselDon
Oil consumption, and the proper checking of the oil levels in Ford diesels comes up periodically. Ford dipsticks are calibrated for hot oil. The 10 quarts in the IDI engines expand about 1/2 to 3/4 of a quart as the oil heats up, and contracts the same amout after cooling. If you check the oil first thing in the morning ( which I grew up doing ) the engines will all indicate oils level below full, but when checked hot, will ( after a 10 minute drain time ) the oil level is usually at full. If you are checking the oil cold, and keeping the level at full, you are actually over filling the engine which will burn of the extra rapidly.
Suggestion: Check oil hot after 10 minute drain time.
Don't add until level reaches add line ( 2 quarts ).
In my days at Ford this often cured, or at least improved, the apparent oil consumption complaints.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 11-23-2005, 03:04 PM   #3 (permalink)
Joe Mc's Avatar
My Photos: (39)
And when it reaches the add line, only add 1 quart.(From the TSB)
Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW
BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
Triple A-pillar pod: Isspro EV voltage and oil-pressure gauges.
Road-Watch System (Air and road-surface temperature gauge).
Chicken Lights Gone.
Joe Mc is offline
Old 11-23-2005, 06:12 PM   #4 (permalink)
Yeah 1 qt per week @ 125 miles per day is 125 X5 is a qt per 625 miles. No worries with consumption. The biggest concern is that the oil pressure be minimum 30 PSI at 3000 RPM on '83- 85 and 40 '86 and later (don't know why they chamged the spec in '86)...
J.D.'s Fords: 1986 F-250 6.9 diesel Solid State Glow Plug System 3.55 gears C-6 2WD 178,960 miles.... it still runs pretty good!
Wishlist H-max turbo, T19 tranny,
1989 Ford Ranger ga$$er, non runner, soon to be donated or scrapped!
jdkline is offline
Old 11-23-2005, 09:51 PM   #5 (permalink)
Actually, it's only about 25 miles per day, 125 per week. The oil pressure stays above 30 psi on the highway(60-65mph).
Trevor in MO
