Oil Pressure Sending Unit Location - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 06-28-2008, 10:49 AM Thread Starter
WhiteGardens's Avatar
So I'm finally putting in a mechanical oil pressure gauge after my oil pressure drops off when the truck is hot. (after about 45 minutes of warm up)
The stock gauge freaks me out. Nice pressure at start up, going down the road, at stop signs it drops just low enough to flixer my engine light.
So whats the easiest way to get to the sender. I'm not sure about the exact location. Does it face upwards and just in front of the bell housing of the tranny? Or facing backwards. I've look at a few diagrams, but they say that this is the general location for most oil senders. (autozone)
JOEMC had suggested plumbing a tee in there to keep my stock gauge and not have a dead gauge. I think I'm going that route, I want to be able to keep my engine light working properly.
Also, I'm going with an 80psi full sweep. I also read from JOE that his pressure never gets up over 75 in the winter. My thinking was also, is that it has a marks for 5, 20, 40psi and up, instead of 20, 40 and up. I also read from CDNSARGUY that hot idle is a minimum of 10psi, so I want to know exactly how much it is droping below 10 if it does.
Also, does any one know what size fittings/ threads in the block for the sender to screw into.
And, the truck seems to be running great, starts good, tracks good, and sqeaks like an 87 truck should. Leaf spring hangers are next on the list though, and I'm wondering if my rear leaf springs are sagging too much, as the 3 spring helpers are starting to ride on the stops unloaded.
Thanks for all the help.
THE BLUE BOMBER! Currently Toast !!!!
87 ford f-350 cab-chassis dually. 2wd, 6.9, 3 speed C-6. 3 leaf helper springs, 11,000 gvwr, pintle/ball hitch, 6 pin round trailer connector (unhooked currently). Rear generic truck stop lights. Twin I beam front end with coil springs. Plow lights and switch to go from headlights to plow lights. 8.5 foot meyer diamond plow with central hydrolics. 8 foot rugby dump bed. 167,000 miles and still strong. Solid State Glow Plug Controller.
WhiteGardens is offline
post #2 of 8 (permalink) Old 06-28-2008, 11:43 AM
suv7734's Avatar
The stock sender is located top/rear of engine against the firewall and can be a real bear to get to. There is also an oil pressure port on the block web, driver's side rear (near the oil filter/behind exhaust) that is a lot easier to get to and takes a 1/8" NPT fitting. Here's a pic...
For every action there is an equal and opposite malfunction
1988 F350 CC 4x4 SRW, 7.3 Banks non-wastegated turbo, C6 w/ HD torque converter, Tru-Cool 4590 trans cooler, Highjacker 'softride' 4" lift, pre/post luber, coolant filter, Racor fuel filter/separator, pyro and boost gauges, Progressive 16x8 wheels, 285-75x16 rubber, 3" downpipe into 4" straight pipe over the rear axle and into 5" SS tip. 1994 Alpenlite 33' 5th wheel trailer
suv7734 is offline
post #3 of 8 (permalink) Old 06-28-2008, 09:23 PM Thread Starter
Awesome Pic. That helps big time. That will be much easier to do. Is that the oil galley plug I've been hearing about? Do you know what size fittings those are??
I was planning on droping the motor by removing the transmission/motor mount block to get a little more room around the sending unit, but that way seems easier.
Is that a steel braided line ??? I'm sure I'm going to have to at least use copper, and sleeve it with poly tubing to help keep it from rubbing anywhere.
God, I hope you don't ever have problems with your exaust stud bolts. My mech. heated them, broke them, drilled, tapped, helicoil, put in GM style bolts and springs, so what a bear.
post #4 of 8 (permalink) Old 06-29-2008, 01:50 PM
That plug in front of the exhaust pipe is the water jacket drain port. The braided line is for the turbo oil feed. That where I also installed my mechanical oil pressure gage by using a TEE. Then years later I changed the mechanical gage to electric. Then it failed. Isspro has vey bad senders and is aware of it. They are changing manufactors soon.
icanfixall is offline
post #5 of 8 (permalink) Old 06-30-2008, 06:27 PM Thread Starter
I don't have a turbo, so I should have a plug there.
Ya, I'll make sure not to get the wrong plug, I would hate to drop any water out of the block.
I looked at your post SUV, thanks for the diameter info.
post #6 of 8 (permalink) Old 06-30-2008, 10:51 PM
suv7734's Avatar
Git 'er dun!
Good luck
suv7734 is offline
post #7 of 8 (permalink) Old 06-14-2009, 04:19 PM
I know this is a year old thread, but I just got a '90 F Super Duty with the 7.3, 5 Speed. Absolutely love the truck, but the stock oil pressure gauge is completely shot and I want to add a Mech. gauge to keep track of the oil pressure.
The picture helped out here alot. I found the plug. I have mounted the gauge, and run the tubing down to where the plug is.....but I absolutely can not get the plug out. I have tried just about every tool I own trying to get a solid grip on this plug and it is just about round right now. Normally when things are this tight I heat them, but the block is soaked in diesel and oil so that is out of the question.
Can anyone provide any advice, or is there another option besides this stubborn plug?
Thanks for the help.
BigOldBeast is offline
post #8 of 8 (permalink) Old 06-14-2009, 05:21 PM
chuckster57's Avatar
As far a pressures go: I have an autometer C2 oil pressure gauge on my pillar. I run DELO 15W-40. I see 40 PSI at startup. After the truck is at operating temp (198 by autometer gauge) and the oil is all warmed up the oil is at 12 PSI at idle and just about 40 @ cruising. Hope this gives you and idea of what they "really" run. My dash gauge is still hooked up and it doesn't even move after the initial reading.
Train Horns:
PM please not visitor message
chuckster57 is online now
