Porportioning Valve - Diesel Forum - TheDieselStop.com
Old 06-17-2009, 10:45 PM   #1 (permalink)
WhiteGardens's Avatar
Porportioning Valve
My RABS light is on. I replaced the sensor, and still no go. As far as I can tell, all the connections look good and have Di-electric grease.
I'm thinking of scraping the RABS system and installing a proportioning valve. I really don't want to drop 450 bucks for parts. Has anyone done this and what kind of results would I be seeing with a dually.
My only concern is the snow, but I usually go slow enough to let the motor do the braking in those conditions.
THE BLUE BOMBER! Currently Toast !!!!
87 ford f-350 cab-chassis dually. 2wd, 6.9, 3 speed C-6. 3 leaf helper springs, 11,000 gvwr, pintle/ball hitch, 6 pin round trailer connector (unhooked currently). Rear generic truck stop lights. Twin I beam front end with coil springs. Plow lights and switch to go from headlights to plow lights. 8.5 foot meyer diamond plow with central hydrolics. 8 foot rugby dump bed. 167,000 miles and still strong. Solid State Glow Plug Controller.
WhiteGardens is offline
Old 06-24-2009, 08:38 PM   #2 (permalink)
Joe Mc's Avatar
My Photos: (39)
I had hoped you would get some good replies on this post. But then I don't like abs and have often wondered how hard it would be to remove.
Duals and a short truck, you might want to keep some weight in the back.
Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW
BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
Triple A-pillar pod: Isspro EV voltage and oil-pressure gauges.
Road-Watch System (Air and road-surface temperature gauge).
Chicken Lights Gone.
Joe Mc is offline
Old 06-24-2009, 10:00 PM   #3 (permalink)
arthurgoboom's Avatar
If you're referring to that mechanical lever brake valve....mine's gone, and it's not bad in the snow that I have noticed, but I don't drive it every day either. I'd think your dump body would be plenty heavy to keep the rears planted.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Wellman G088 glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 06-25-2009, 10:30 AM   #4 (permalink)
Joe Mc's Avatar
My Photos: (39)
For the 1987 year Ford came out with a Rear ABS system to replace the lever used in the 86s.
Joe Mc is offline
Old 06-25-2009, 07:48 PM   #5 (permalink)
Thanks for the replies.
Is the master cylinder a little bigger on the 87 also ??? Thought I read that somewhere.
I really want to do away with the RABS, Pete sent me some info on diagnosing the problem. I'll try to tackle that when it's not so hot out. If something is amiss besides a stupid electrical connection, then I'm taking out the RABS and not even fooling with paying to replace the components.
In order to plow in the winter, I put two tons in the dump bed for traction. Without having a posi, and being 2wd, it doesn't do to bad. The only time I have traction issues is plowing heavy wet snow, and even then I have a set of short chains to throw down to get traction if I get stuck.
So, needless to say I'll have plenty of weight going down the road, and when it's really bad, I usually don't go faster than 35, 40 tops. I also slow down way ahead of time and let the motor slow me down to hold traction with the tires.
So far, every mechanic I talk to thinks I'll be O.K. with the conversion as long as I get it adjusted correctly. I also would like to mount the knob in the cab so I can adjust it on the fly if I need to.
Old 06-27-2009, 01:16 PM   #6 (permalink)
OK, so here is the new dilemma.
If, I use a proportioning valve, do I get an adjustable one, or a little more expensive one that has the automatic metering valves in them ??
Old 07-06-2009, 01:18 AM   #7 (permalink)
Here it is, I'm hoping to have it in 5 days or so. I need to re-do the front brakes, and would like to get it installed asap.
Tilton adjustable brake proportioning valve IMCA NASCAR:eBay Motors (item 180375116596 end time Jul-05-09 19:46:19 PDT)
I'll re-post on here when I get it done.
Also, anyone done the F-450 hydro boost conversion?? Does the master match up to the booster ???
Old 07-08-2009, 10:16 PM   #8 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Does your 350 not have the adjustable load braking mechanism on the rear axle. I was under the impression there is an adjustable brake system for the rear axle. IE if you have a light load the you get light application of brakes....... if you load it up then the rear brakes compensate for the load.......
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 07-08-2009, 10:50 PM   #9 (permalink)
Joe Mc's Avatar
My Photos: (39)
cdnsarguy,
That is the system the 86 trucks had, in 87 Ford went to rear abs.
Joe Mc is offline
Old 07-08-2009, 11:23 PM   #10 (permalink)
1987IDI's Avatar
My Photos: (14)
Originally Posted by Joe Mc View Post
cdnsarguy,
I understand the lever type they are talking about from an old dodge i had, how does the rear abs work on the 87 and up? Does it have a wheel speed sensor? or is that what that little sensor on the top of the diff is for?
1987 F250 XLT Lariat
Regular Cab 2x4 6.9L 5-Speed
Homemade Propane Injection.
RUNS ON PURE WASTE MOTOR OIL!
No more diesel for me...
1987IDI is offline
Old 07-09-2009, 10:48 AM   #11 (permalink)
Yes, there is a speed sensor in the rear dif. The RABS proportioning valve is located on the frame under the drivers-side of the cab.
Old 07-10-2009, 04:08 AM   #12 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Joe Mc
The Height Sensing Brake Proportioning valve setup was still used on the Cab and Chassis trucks in 1993...... Whitegardens just has an older model.
Old 07-10-2009, 10:38 AM   #13 (permalink)
Originally Posted by cdnsarguy View Post
Joe Mc
Would there be a load sensor along with the RABS valve ????
Old 07-10-2009, 11:14 AM   #14 (permalink)
FMTRVT's Avatar
My Photos: (16)
I’ve been staying out of this discussion as I usually just hang in the 99 and up forums, but I’ll throw in my $0.02 worth. And I'm going to get wordy while I'm doing something else.
I actually liked the mechanical prop valve located at the rear axle. When working and properly set up, it proportionally kept the rear brakes from skidding too early and provides reasonable full braking effectiveness. These were not only used on pickups, but Chrysler Minivans also used them. There are some issues though.
One is of course that it is mechanically working. The second is that it is setup correctly, which in order to service you need pressure readings from both the front and rear brakes, usually lacking in home projects and often lacked even at dealerships.
Another issue is that it’s not ideal. Disc brakes are very linear in braking. How much pressure is applied gets you corresponding braking. Duo-servo drum brakes are not. The output increases based on both the line pressure and the servo effects. So if you’re applying 2000 psi rather then 1000 psi, your going to get a whole lot more rear braking then expected.
Proportioning valves don’t account for this; even the older props located by the master cylinder or the adjustable ones. The older set prop may have been designated 300/.43. This means you have full pressure to the rear brakes until the 300 psi point, then the rear pressure is proportioned at a 43% of everything over 300 psi. In a hard stop at 1000 psi, you’re getting 601 psi with that prop.
What ends up in the engineering lab is that you make a compromise in the rear braking ability. You might design the system so the rear brakes will not skid worst case with no load in the bed, but then your not getting full braking under heavy load (weight preventing tire skid) that you could be getting. All of this depends on your expectations of how hard the driver will end up pressing on the pedal. If the truck is lightweight and he is making a close to panic stop, will he restrain how much he is pushing on the brake to the point of incipient skid and getting ideal stopping distance. Or is he going to be heavy footed and just skid.
The RABS was an attempt to correct for the both the set point prop issues as well as the mechanical issues of the height sensing prop valve. Adjust the pressure only when the deceleration rate is theoretically high enough that a skid would occur. Basically the software reads how fast the tone ring in the differential is slowing.
But I hate RABS. Drum brakes by their nature have a high degree of hysteresis– they don’t react fast to apply and release as disc brakes do. And neither does the RABS valve. Plus the RABS system does not incorporate a pump to regenerate the hydraulic pressure that it dumps. So each dump and re-engagement of the rear brake circuit requires volume from the master cylinder, so you end up with constantly dropping pedal while it’s doing its thing. The 4 wheel ABS just does such a better job. But it does end up providing a better stopping distance for those who are not that informed or trained about applying the brakes to generate incipient skid. That is if the prop valve is first selected properly from the factory.
To the question can you set up a proportioning valve in place of the existing unit? Yep, at your own liability risk. The common adjustable valves have been around for a long time, originally supplied by Kelsey-Hayes, which is now TRW. They are a simple valve, not like the combination valves of years past, where those valves included a pressure differential valve to limit fluid loss with a system failure, possibly a metering valve to slow application of the front brakes (allowing the rear brakes some time due to their hysteresis), and an electrical switch to light up a dash lamp to tell the driver of a problem.
The typical 2-port adj prop you’re going to find will have a set slope, like the .43 in the example above. What your able to adjust is the cut-in point, from 100 psi to whatever. They are not hard to install and we used to do this all the time when developing new friction material formulas for a new vehicle platform years ago before 4WABS. The new line is run from the rear brake port of the master cylinder into the cabin, then a return line back out to the existing rar brake line that used to be attached to the M/C. Connecting this up can be an issue, but NAPA stores carry WeatherHead fittings that allow you to do this. The guy behind the counter will not be able to match up parts, so it will be you looking through all the bins in the display to find what you need. The other thing you need to do is disconnect the existing prop valve and bypass it with hard line.
Here are some reference materials.
Proportioning Valves
StopTech : Balanced Brake Upgrades
www.tiltonracing.com/pdfs/98-1261_Prop_valves.pdf
Now keep in mind that your taking on the liability for how well your vehicle stops. Some S-O-B like me may be called in if you have an accident and run into someone, and the police, plaintiff, or insurance company sees what you have. And the acting accident reconstructionist will then evaluate if you did a good job of engineering your brake system, and if it had been properly adjusted the vehicle could have stopped 20 ft shorter and my client would not have been injured.
For your last question, there was no "load sensor". The mechanical lever connection adjusted the prop valve depending on the sag of the vehicle (bow of the leaf springs) between the rear axle and vehicle frame.
Jack
Truck Modifications below in Pictorials on Facebook. Search in Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is online now
Old 07-10-2009, 05:05 PM   #15 (permalink)
Great Post.
It's funny that you mentioned all the things in your post, only because of the lot of thinking I do, and trying to take most of those points in consideration.
So, if I'm reading you correctly, even with the adjustable proportioning valve, there is going to be the variables of driver input, and load weight.
I was looking at the Astro-van MC and Hydro boost and noticed that GM had a proportioning valve that (how I would describe) metered the pressure to the rear brakes in relation to the pressure of the front disks. If I've read correctly does this mean that it adjusts properly to compensate for driver input ?? This would probably be the better setup as it would leave less room for error with no manual adjustability.
I used to like my RABS until I had issues with the rear dif, and a couple of panic stops left me white as a gost. The last time I used the truck, I noticed that my RABS light wen out and I don't seem to have the break-fade that I had before.
I understand what you are saying about liability. Something that I didn't take into consideration. I would still think that I would have a little more peice of mind stopping with the porportioning valve knowing how it's going to react rather than a RABS system that has a mind of it's own.
My other thought is, that I want to mount the lever for the valve in the cab so I have adjustability on the fly, loaded or un-loaded. I also chose the lever style with 7 positions as you might loose the position of the knob-style more easily if you tweak it too many times.
I don't know, the way it is now, it's almost scary. I drive it like a dump-truck so my following distance is greater than average and I'm always at or below the speed limit, but once you need to stop in a hurry, I want that reliability.
Regardless, even if I install the manual valve, I'll need to do some thorough testing loaded and un-loaded to achieve the best results, and mark those positions on the valve. My neighbor is a big-rig Mech, so he might have something to measure line pressure after initial setup.
Potentially, I might also up-grade the rear drums to disk. I found a company out there that has designed a kit for the dually, utilizing a Lincoln disk and caliper. (usually only see the kit for the single wheel, so I was surprised to find the kit). If that happens I'll probably have to re-configure the prop-valve again.
Thanks for the post FMTRVT, if you've got any more thoughts or insight into this, by all means feel free to post.
Also, I don't think I have the load sensor/lever on my truck.
