Power Steering Adjustment. - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 10-20-2005, 08:08 AM Thread Starter
My 84 F250 power steering is wandering all over the road. Suspect I will need to replace the Steering gear box, but would like to try to get the slack out of the Steering gear box first. Can I just adjust the preload without having to remove the Pitman Arm and draining the Steering gear box fluid as it states in the repair manual without sacrificing safety? Which way should I be turning the preload adjusting screw to take up the slack and in what increments?
treetop333 is offline
post #2 of 3 (permalink) Old 10-20-2005, 03:09 PM
Re: Power Steering Adjustment.
I don't know why you would have to drain the oil, etc.
With the wheels straight ahead, loosen the jam nut, then turn the stud clockwise until it just bottoms (do not tighten it any further). While holding the stud, retighten the jam nut.
Once you have done this, carefully test drive the truck to make sure there is no binding in turns. Since the gears tend to wear more in the straight ahead position, if there is a lot of wear there can be binding in turns when the gears mesh in a lesser worn area.
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
post #3 of 3 (permalink) Old 10-20-2005, 05:34 PM Thread Starter
I will give that a try this weekend.
