Proceedure for cleaning the CDR - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 08-16-2006, 12:30 AM Thread Starter
Spencnaz's Avatar
My Photos: (14)
I figure that while I still remember how to tear down the PowerSmoke.....
What's the steps to teardown and clean the CDR? I have on the in the intake tube to my Hypermax turbo. It probably could use a cleaning.
The Green Monster
: 2001 F250 Powerstroke, 2WD, ZF6 transmission. Bully Dog GT Tuner set in tow mode. MotorSilk boric oxide added to engine, transmission and diff. Showing 30mpg on the freeway running home brew biodiesel. NTZ 1/2 Micron bypass oil filter. Dieselsite coolant filter. 4" open turbo back exhaust. Ford AIS intake. Donaldson ELF7405 oil filter. Caterpillar ELC next on the list.
Spencnaz is offline
post #2 of 9 (permalink) Old 08-16-2006, 12:48 AM
cdnsarguy's Avatar
My Photos: (109)
Re: Proceedure for cleaning the CDR
Do you know when to service your CDR valve?
All 6.9L and 7.3L diesel engines are equipped with a CDR (Crankcase Depression Regulator) valve. Even the new 7.3L Power Stroke is also equipped with the same valve. The CDR valve is one of the leading causes of head gasket failure in these engines. The CDR valve is responsible for controlling the pressure/vacuum in the engine crankcase, and seperating the oil mist from the air and returning the oil to the crankcase. The CDR valve should be serviced every second oil change or when signs listed below are seen.
When the CDR valve is not properly serviced, engine oil enters the air intake and is drawn into the engine. The diesel engine will burn this oil as fuel, however, it is heavier and thicker than diesel fuel and, having greater BTU output, causes excessive heat in the cylinder. Due to the intake manifold design, most of the oil will migrate to #7 and #8 cylinders; the last two cylinders in the rear by the firewall. The increased temperature here will cause the cylinder head to lift off the gasket and allow water or oil to leak out the back of the cylinder head where it meets the block.
To check your CDR valve, remove the air cleaner hold down bolt and inspect it. If the bolt is covered with engine oil mist, it's time to service your CDR valve! Ford calls this item a "Adapter assembly for Crankcase Ventilation" Part number E3TZ-6A665-A or IH part #1805319C1
To service the CDR wash with a solvent, allow to dry, do not use compressed air to dry. There is a small hole in the CDR back cover, ensure it is clean and open. If black chunks of rubber are visible in the intake, on the screen then the rubber membrane has disintegrated, replace the CDR.
IH part #1805319C1
The part # for the rubber tube on the CDR... Retainer # E8TZ 6A892A Might want to check IH for part #.......
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #3 of 9 (permalink) Old 08-16-2006, 10:46 AM Thread Starter
Spencnaz's Avatar
My Photos: (14)
Ok sounds like I really need to service that CDR then, there is a film of oil inside the intake tube to the turbo. The CDR is mounted to a flange on this tube.
Does the CDR come apart in an orderly fashion to check it's internal components and for cleaning?
The Green Monster
Spencnaz is offline
post #4 of 9 (permalink) Old 08-16-2006, 12:21 PM
They don't come apart. You clean the unit through the 2 holes.
My recomendation is to buy a new one, and then clean it on a regular basis. That way you know that you are starting with a good, newer part rather than an unknown unit.
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
post #5 of 9 (permalink) Old 08-16-2006, 12:44 PM Thread Starter
Spencnaz's Avatar
My Photos: (14)
Should a generic parts house have this unit, like Schmucks or AutoZone?
The tube leading to the CDR is coming from an elbow on the valve cover.
The Green Monster
Spencnaz is offline
post #6 of 9 (permalink) Old 08-16-2006, 02:28 PM
They are common enough that parts stores may carry them. They will probably list it as a PCV valve.
post #7 of 9 (permalink) Old 08-16-2006, 02:36 PM Thread Starter
Spencnaz's Avatar
My Photos: (14)
Ok, if I can't get one quickly, what solvent do I use to clean out the CDR?
The Green Monster
Spencnaz is offline
post #8 of 9 (permalink) Old 05-26-2011, 08:50 AM
Kevin 007's Avatar
diesel fuel perhaps?
1984 F-250 6.9, T-19, BW1345, BB code injectors, low mileage, manual Beru Glow Plugs, D70 rear end. solid truck.
1985 Toyota Landcruiser BJ60, 5 bearing cam 3B 4cyl diesel, H55F trans. Best rig I have ever owned.
1981 Honda Trail 110.
Kevin 007 is offline
post #9 of 9 (permalink) Old 05-26-2011, 09:41 AM
drinkypoo's Avatar
My Photos: (25)
people have destroyed them with strong solvents so it is probably a very bad idea to use anything stronger than diesel fuel.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
