Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > 6.9L Diesels
Old 11-04-2009, 11:03 PM   #1 (permalink)
biodieselLuke's Avatar
which rear lift springs? and where to get em
I just finished doing a solid axle swap on my 86 2wd and I need to bring up the rear. I used v code super duty springs which feel pretty soft and I would like to have something comparable in the rear. Load capacity doesnt matter so much as I plan on installing some air bags later. I don't want to just block up the rear cause those springs are already 23 years old and it didn't ride that smoothly off the lot. Suggestions? something in like a 4-6 inch lift range would match the front pretty closely I think.
02 f550 crew cab, harbor body, 322k, BTS, edge juice w/attitude, Itp reg. return, turbomaster, ebpv delete, HP x-over, ford ais, aih delete, Diesel innovations up pipe, 4" cat back, ccv delete
86 f250 4x2 4 speed 6.9 125k
85 300sd 256k
biodieselLuke is offline
Old 11-04-2009, 11:24 PM   #2 (permalink)
speeddemon31176's Avatar
Send a message via AIM to speeddemon31176 Send a message via Yahoo to speeddemon31176
I am partial to skyjacker springs as I have had two different sets of superlift rear springs that both broke on me(made in indonesia). there are other companies on the net that will make up leaf packs to your specs with several thinner leaves in order to attain better ride quality.
97 F-350,4X4, CC, LWB, PSD, 251k, K&N, 10K MOD
speeddemon31176 is offline
Old 11-05-2009, 10:19 AM   #3 (permalink)
Rear SD B codes..I don't know if they will fit..they will on a '95-97.
caryt is offline
Old 11-07-2009, 12:30 AM   #4 (permalink)
do these provide any lift on OBS trucks? Also, any recommendations on what shocks to run?
85 300sd 256k
Old 11-09-2009, 03:03 PM   #5 (permalink)
Bilsteins from cary!!!!!!
01 Excursion Diesel 4x4 family wagon,3" lift,33" Bfg,afe stg 2,hypertech.....
97 f350 4x4 crew cag long bed
,4"lift,35" toyo's,afe stg 2,mbrp 4" straight exhaust,more to come...........
Also 66 bronco frame off......77 flh shovelhead
01 Excursion Family Wagon is offline
Old 11-09-2009, 10:51 PM   #6 (permalink)
My Photos: (54)
Moved from 94-97 PowerStroke General forum.
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed manual, two wheel drive, 3.55 gears, 286,000 miles, LUK clutch conversion, 450 lb homemade REAR BUMPER, homemade open element AIR FILTER, 36" tall ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
