Restart after running out of fuel - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 06-25-2010, 11:49 PM Thread Starter
I ran out of fuel as I arrived at the pump today. After I fueled up, truck would not start. I eventually got it running to the point that I could get it out of everyone's way. Cannot restart the truck. Had to leave it overnight. What do I need to do to get the beast running again?
RDBennett is offline
post #2 of 11 (permalink) Old 06-26-2010, 12:12 AM
chuckster57's Avatar
If you got it to start and run enough to move it from the pumps, then you're all but done allready. Make sure the batteries are fully charged and then try to start again. You could bleed the lines by loosening the fuel line from an injector and try starting until you get fuel. But I think that it is just about bled, Just get it to kick and then feather the throttle to keep it running til it smooths out. Might take a minute or two.
Train Horns:
PM please not visitor message
chuckster57 is online now
post #3 of 11 (permalink) Old 06-26-2010, 03:09 AM
Joe Mc's Avatar
My Photos: (39)
If you take a car back to the station, jump-start the truck to get more starting power.
Keep the throttle on the floor while cranking, you want the IP to move as much fuel as it can.
Make sure the fuel filter is full, you may need to bleed the air out of the filter.
If you do need to bleed the lines never touch the line-nuts with your hands, only with a wrench. The system has enough pressure to inject fuel through the skin.
Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW
BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
135,016 miles: Rear-ended and totaled by an uninsured kid having a temper-tantrum
1999 Rav4 AWD 5-speed, AC, PS, PB, CC, Sunroof.
Joe Mc is offline
post #4 of 11 (permalink) Old 06-26-2010, 08:45 AM
cdnsarguy's Avatar
My Photos: (109)
How much fuel in the tank selected must be over 1/3 (possible fuel pickup problem).
Always drain air from the filter first while cranking until a good stream of fuel comes out (need a rag). Now with your foot to the floor crank the engine....yes I still pump it like a gasser with some results....... there are still things opening and closing in the IP which move air out. Don't over do the starter.....if it is a manual trans tow start it.... FASTER.
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #5 of 11 (permalink) Old 06-27-2010, 10:07 PM Thread Starter
1/2 tank of fuel.
I had a friend cranked the engine while I checked the valve at the fuel filter, no flow. We cracked all the injection lines, no fuel.
I disconnect the supply line from the filter, no fuel.
We checked for suction from the fuel line while cranking the engine, no vacuum.
I have to assume at this point that I have air between the tank and the pump or I have a plugged fuel pickup. Agree disagree.
Towed the truck home, sitting in my shop.
post #6 of 11 (permalink) Old 06-27-2010, 10:29 PM
Probably full of air. Fill the filter with fuel and see what happens. If the lines went dry, it takes a LOT for the lift pump to pull a vacum all the way from the tank(s). I don't know if the starter can turn the engine fast enough for the fuel pump to cycle fast enough to overcome the air in the lines.
When a gasser runs out of fuel and the lines go dry, a little fuel in the intake will make the engine fire up and the mechanical pump cycle fast enough to get a prime. CAN'T do that with a diesel.
Train Horns:
post #7 of 11 (permalink) Old 06-28-2010, 08:14 AM
cdnsarguy's Avatar
My Photos: (109)
Before you start tearing things apart.... Fill the filter as stated, check for power at the front drivers side spade terminal on the IP....... KEY ON.
You can also try spraying WD 40 in the intake and cycling the GPs as normal while cranking. Do not spray too large an amount to cause pooling....just misting.
"Remember to cycle the key off and back on so as to cause the GP controller to heat the GPs on "EVERY" start attempt.
post #8 of 11 (permalink) Old 06-29-2010, 12:54 AM Thread Starter
The filter is full of fuel. Has been all along. My plan is to disconnect the supply line from the filter and apply compressed air to clear any debris at the pickup in the tank. Curious as to whether there is a screen or is the fuel pickup just a tube? Seems like I could reverse this and apply air at the tank side and try to push fuel up the supply line to the filter and then tighten it down. Then I would do the injector lines. I will also try the wd40 technique as well. Appreciate all the help.
post #9 of 11 (permalink) Old 06-29-2010, 06:26 AM
Joe Mc's Avatar
My Photos: (39)
If your filter is full of fuel, then you only need to bleed the injector lines.
Trying to put compressed air through the fuel lines does not sound like a good plan.
To bleed the injector lines:
Crack the nut on top the injectors about a quarter turn.
Crank the engine with the throttle to the floor. Crank 10 seconds, wait 2 minutes.
When a line starts getting damp close the nut with a wrench.
Should start before you get all eight closed.
May not be the fuel system, it could be an electrical problem. Make sure you get 12 volts at the FSS (fuel shutoff solenoid) both with the key in the on position and the start position. If the FSS does not get 12 volts while cranking it will never start. Mine ran fine one-day and would not start the next day because of a $9 switch.
Joe Mc is offline
post #10 of 11 (permalink) Old 07-10-2010, 12:27 PM Thread Starter
Finally getting around to working on my truck.
Here are the facts:
Fuel in the filter. When trying to start, no fuel coming out of the schrader valve. Cracked open all the injector lines to bleed, no fuel.
Pulled the fuel line on the supply side of the filter, no fuel when turning the engine over.
Pulled the fuel line on the supply side of the fuel pump, no fuel coming from the tank.
Questions:
could the pickup tube in the tank be plugged? Remember, I ran out of fuel when I pulled up to the station.
Joe said something about the FSS failing. Could this be a coincidence that this would fail at the same time I ran out of fuel? The truck was working perfectly up to this point.
Next question. Where is the FSS on the engine and what is it's purpose? How does it affect the fuel system?
Thanks for all your help.
post #11 of 11 (permalink) Old 07-10-2010, 05:38 PM
Joe Mc's Avatar
My Photos: (39)
Sounds like the lift pump died or you have an air-leak between the lift-pump and tank. You may not have run out of fuel.
Although it is surprising that the fuel filter is full.
FSS, the fuel shut-off solenoid lets the IP pump fuel to the injectors when the solenoid is open and cuts-off the fuel when it is closed there-by stopping your engine. Of the 2 wires going to the top of the IP, the fss is the one closer to the front bumper.
Joe Mc is offline
