Restrictor plate? - Diesel Forum - TheDieselStop.com
Old 08-23-2007, 12:24 PM   #1 (permalink)
Zork's Avatar
Restrictor plate?
Did someone here post about drilling out a restrictor plate on a 6.9 intake? I know that there is a post on drilling 20 holes in filter housing to the equivalent of 1.5", but I could not find it there.
The full loath honey, but to the hungry- even what is bitter tastes sweet.
Zork is offline
Old 08-23-2007, 02:45 PM   #2 (permalink)
Spencnaz's Avatar
My Photos: (14)
Re: Restrictor plate?
The best way to remove restriction on a NA 6.9 is to remove the 'soup bowl' from the air cleaner housing.
I know of no restrictor plate on the 6.9, normally all diesels have wide open intake tracts.
Spencnaz is offline
Old 08-23-2007, 03:58 PM   #3 (permalink)
Zork's Avatar
OK, thanks for the help, but whats the soup bowl? The filter housing seems to be much smaller than the larger intake opening.
Zork is offline
Old 08-23-2007, 06:35 PM   #4 (permalink)
Spencnaz's Avatar
My Photos: (14)
The soup bowl is inside the air cleaner housing. It's a huge bowl shaped object that IH put in there I think to silence intake noise, but the engine is loud enough as it is.
All it does is restrict airflow and should be taken out.
Spencnaz is offline
Old 08-23-2007, 07:23 PM   #5 (permalink)
Send a message via AIM to VD350
There is a restrictor plate. Some came with it others did not. I'll find my post from before. I made a post about drilling it out.
Here ya go
http://forums.thedieselstop.com/ubbthrea...rue#Post3247979
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
www.Fordemblem.com
My Truck and My Yamaha Tri-Z
VD350 is offline
Old 08-26-2007, 02:05 PM   #6 (permalink)
87diesel69's Avatar
My Photos: (29)
here a pic of the plate I took out of my intake
http://photos.thedieselstop.com/show...t=1&thecat=500
http://photos.thedieselstop.com/show...ium&thecat=500
1987 f250 6.9 ZF5 with luk clutch 3.55 4x4 350,XXXKm
6inch lift, 325/75/16 Mickey Thomson MTZ
5inch chrome stacks
6.9 built in June of 1987 The last of the 6.9s
on/off switch on GP timer
Welding my dana 50 together!!
1994 f250 ext cab 7.3 turbo 4x4 5speed
87diesel69 is offline
Old 08-26-2007, 02:33 PM   #7 (permalink)
Yep the Jolley 'ol Retard plate. You should notice a difference, if nothing else a little better fuel economy and less smoke
www.Fordemblem.com
VD350 is offline
