Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > 6.9L Diesels
Old 07-31-2008, 12:31 PM   #1 (permalink)
smelled chicken and rice - burnt rubber - then shut down. now won't start
Title pretty much says it all.
87 F250.
I was on my way home, smelled chicken and rice then burnt rubber, then the truck just shut off. no weird sounds or anything....tried to crank and just get jud-jud-jud-jud-jud but won't turn over.
little background info - the engine was supposedly rebuilt 40,000 miles ago and the tranny was def rebuilt 3,000 miles ago.
I've only had it a month or so...just changed the fuel filter and put on a new starter (old one was apparently hanging by one bolt and had one crank to many like that)...
can't think of anything else that may help...
I thought maybe a belt of some sort broke but there appear to be no naked pulleys.
thank you so much for your help
ugly greasanova is offline
Old 07-31-2008, 01:23 PM   #2 (permalink)
bockhold's Avatar
Send a message via AIM to bockhold
Have you checked your wiring on the engine? Did you pinpoint location of the smell?
Jarrod
NRA member
1997 F350 4door 2wd long bed white 7.3L Powerstroke, E4OD, C5 4:10LS diff 326K miles on org engine
and is being repaired
bockhold is offline
Old 07-31-2008, 02:07 PM   #3 (permalink)
Joe Mc's Avatar
My Photos: (27)
Make sure you are getting power at the FSS (fuel shut-off solenoid) both when you turn the key on and during cranking. Also check to see if any other circuits are dead. Sounds like you cooked something.
Red 86 F250 Supercab XLT, Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Remote lube TOB.
BOOB man - Brotherhood of Oil Burners
Joe Mc is offline
Old 07-31-2008, 02:37 PM   #4 (permalink)
I couldn't pinpoint a location for the smell...
i'm going to do some searches right now to try and find out where the fuel shut-off solenoid is.
thank you so much!
Old 07-31-2008, 04:54 PM   #5 (permalink)
found the FSS...
If I disconnect and then reconnect a connection on the FSS while the ignition key is turned on, should I hear the FSS click or engage at all?
b/c I dont...
thanks
Old 07-31-2008, 05:53 PM   #6 (permalink)
chuckster57's Avatar
Originally Posted by ugly greasanova View Post
found the FSS...
b/c I dont...
thanks
Yes you should. To be sure, it is the one to the rear on the drivers side of the IP. It will "click" ...time to start backtracing the wire if you don't have 12V at the connection.
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually,
1997 Jayco fifth wheel 323 RKS, Robins 16K dual axis hitch
Apillar pod with: Autometer C2 Series gauges: pyro,trans, boost
Hypermax Cowl induction, Flex-A-Lite 26K tranny cooler w/fan
K&N air filter (we'll see in a million miles)
Tekonsha "prodigy" brake control
Train Horns: Pictures here
chuckster57 is offline
Old 07-31-2008, 08:01 PM   #7 (permalink)
CDX825's Avatar
My Photos: (9)
Send a message via AIM to CDX825 Send a message via Yahoo to CDX825
Welcome to the forum UG! Glad to see you made the trip here! Hope you track down your electrical problem. One way you could easily check to see if that is the only problem stopping the engine from running would be to hook the terminal the red wire goes to up to the battery and try starting it. If it fires up then you know for sure its an electrical issue.
1984 F250 6.9 C6 2WD Pushbutton Wellman GPs, True Flow air filter, 7.3 IDI air cleaner Cover with no Soup bowl.
CDX825 is offline
Old 07-31-2008, 11:26 PM   #8 (permalink)
cdnsarguy's Avatar
My Photos: (66)
The FSS is the front (lg) spade connector on the drivers side (USA) of the IP, the timing advance is the (sm) rear connector ..... see my photo link. Your truck should have the Solid State GP system so ensure the schematics you search for wiring info reflect that system.
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 07-31-2008, 11:34 PM   #9 (permalink)
Thanks for the correction. I was looking at your photo and then running outside to the driveway and trying it. I must have been standing on my head when I looked at the picture, Or I'm dyslexic (sp), or MOST PROBABLY I am getting old and suffering from short term CRS
Old 08-02-2008, 01:12 PM   #10 (permalink)
Thank you all! I'm really glad that I found this forum!
So I used a jumper wire to engage the FSS and I could hear it click, but it still wouldn't crank....
any idea what to look for next?
It seems weird that the FSS wasn't engaging - but that apparently isn't the problem?
my glow plug, or "wait to start" light isn't coming on at all when I turn the key....the guy that I bought it from had new gp's put in and a new gp relay...
thank you!
Old 08-02-2008, 02:27 PM   #11 (permalink)
Do you mean the engine won't turn over or it does and just doesn't start?
Old 08-02-2008, 02:45 PM   #12 (permalink)
it goes "jud-jud-jud-jud-jud"
but shows no sign of actually cranking...
Old 08-02-2008, 05:08 PM   #13 (permalink)
CDX825's Avatar
My Photos: (9)
If your glow plugs are not turning on it will make it hard to start. You could try pluging in the block heater for awhile.
CDX825 is offline
Old 08-02-2008, 05:13 PM   #14 (permalink)
i think i found the culprit!
I followed the wires back and found a blown fuse. It looks like someone hacked in and put a couple of fuses....
when I put the new fuse in the glow plug light came on and I could here the fss engage...
but now my batteries are dead and i cant get it to do a dang thing.
Got it on the charger, hopefully we'll be good in a while.
Thanks a lot for all the help!
Old 08-07-2008, 02:17 AM   #15 (permalink)
Fuses??? I wonder why someone did that.....
I don't have a schematic of the wiring, but that doesn't sound right at all...
Depending on the type of fuses (the old style glass or blade), I'd put in a CB instead. If the fuse is the blade type, getting a CB to fit the holder is no issue (I did that w/ my tail/park lights on my pickup).
But the thing that bothers me is, what caused the fuse to blow???
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Kaliburz is online now
