Smokin White smoke at start. - Diesel Forum - TheDieselStop.com
Old 11-29-2005, 05:19 PM   #1 (permalink)
Hey guys, had a question, my 86 just got new head gskts, and i put ARP head studds, new injectors, new glow plugs, the valve springs, the whole deal. I have the banks turbo kit on it and right now it runs great, but when i start it it chugs white smoke out, its not coolant, its white oil smoke. Im guessing its gota do with the turbo. I can shut the truck off wait 3-4 min. and turn it back on and it does it again, after about 30 sec. of chuggin smoke it clears up. As for anything else, it seems to be running fine, but it burns alot of oil. Any ideas guys? thanks for the help.
4doogie is offline
Old 11-29-2005, 07:47 PM   #2 (permalink)
Re: Smokin White smoke at start.
SOUNDS LIKE A TIMING or glow plug issue to me !How old is the fuel pump and what kinda plugs did you use?
86 F250,SC,4x4 Patched and patched and patched!335000 km and still patchin!
Fred
Fred Hemer is offline
Old 11-30-2005, 12:28 AM   #3 (permalink)
There's a switch that controls the advance soleniod on the right side of the engine just above the thermostat, follow the wires from the injection pump it will lead you to it, it may be disconnected, damaged etc...
1996 F250 4X4 Crew Cab Short Box
dougc70 is offline
Old 11-30-2005, 02:56 AM   #4 (permalink)
I'm going to agree with Fred. Timing. I was stubborn with these guys about this when I did my head gaskets. Thought I could not have jumped timing but I did. You need to ahve it checked with tools. Sounds like great project otherwise. I'll bet that thing is 2-3 degrees retarded or if not you might have a small air leak at startup. Drainback problem. Very common.
J.D.
J.D.'s Fords: 1986 F-250 6.9 diesel Solid State Glow Plug System 3.55 gears C-6 2WD 178,960 miles.... it still runs pretty good!
Wishlist H-max turbo, T19 tranny,
1989 Ford Ranger ga$$er, non runner, soon to be donated or scrapped!
jdkline is offline
Old 12-01-2005, 12:09 AM   #5 (permalink)
farnereinar's Avatar
My Photos: (6)
ive heard of the newer powerstrokes (94-97) doing that because of o-ring problems in each injector dumping fuel into the cylinder...
usually white smoke on a head gasket job means the thing got botched.....maybe some dealer nerd started and reved the heck out of it before it was properly sealed? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
daily: 2000 F-350xl 7.3L 4x4 SRW Reg Cab, auto, edge juice with attitude, DIY intake, 4" exhaust, 2.5" lift front & rear, 33" goodyears
work: 1995 F-superduty 2x4 7.3L Dump e40d, heavy and slow
1985 F-350 Diesel 6.9 4x4 Reg Cab SRW c-6 automatic connected to a borg-werner 1345 TC, 4:10 posi d-50 front and sterling 10.25 rear, TTB, A/C, new springs, shocks, starter, 450amp alternator new floors rockers wheel wells, doors, hood, fenders & black paint
HERE SHE IS
accident in feb. 2006 left her totaled, but will be re-bent to perfection in time.
dads: 1992 non-turbo 7.3 e4od 4x4 extended cab 3.73rears 265k miles, runs like crap, looks like an angry cloud.
farnereinar is offline
