Source for rebuilt cruise control servo's - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 11-09-2005, 01:21 PM Thread Starter
The cruise control on my 1986 F250 is going out. I'm pretty sure the diaphragm in the servo has a leak because you can engage the cruise, then use your foot to get it to the correct speed and it will hold it awhile. If you just set it, it wont pull the throttle. I can remeber when you could get complete rebuilt cruise control units. So far no luck. Anybody have a source?
Diesel Mechanic 34 yrs Maintenece Manager 23 yrs
Garbage_Mechanic is offline
post #2 of 5 (permalink) Old 11-09-2005, 08:51 PM
LRH
Re: Source for rebuilt cruise control servo's
A lot speedometer shops also do cruise control parts. One I did business with years ago did Ford and GM cruise control parts as well as factory radios/amps on an exchange basis during the warranty period.
LRH is offline
post #3 of 5 (permalink) Old 11-09-2005, 09:22 PM
There is a dump valve on the brake pedel that may be out of adjustment. If that isn't right it will leak vacuum and give similiar symptoms that you describe. Might be worth a look.
Good luck,
Doug
'86 F-250 4x4
'89 E-250 ATS
Doug Bensen is offline
post #4 of 5 (permalink) Old 11-09-2005, 10:31 PM Thread Starter
Thanks guys, both great ideas! Keep em comin!
post #5 of 5 (permalink) Old 11-11-2005, 10:08 AM
Got to thinking about low vacuum. There is another vacuum can on the drivers side almost directly under the servo. Mine was very rusted out. Looks like the fruit juice can. Keep us posted.
Thanks, Doug
