Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > 6.9L Diesels
Old 08-22-2008, 03:37 PM   #1 (permalink)
super ignorant question
I've wanted an older pickup since I can remember and am finally in a place to be able to buy one. I found an '86 F250 6.9L diesel that is a beauty. It's a manual transmission but a 4 speed. I've never driven less than a 5 speed. I want to use the truck for hauling/towing and will need to freeway commute 40 miles (each way). My commuting time will be daily for a few months and then just a couple times a week after that. The salesman seemed to think a 4spd wouldn't travel well at freeway speeds. Is this true? I am a pretty tame driver but don't want to feel like I'm killing the truck going the speed limit. Any input from folks who have this same rig?
brettz is offline
Old 08-22-2008, 04:58 PM   #2 (permalink)
WhiteGardens's Avatar
I don't own a four speed. If you want to think your destroying your truck at highway speeds, then get one with a three speed auto (C-6). Nothing like driving 55 at 2500 rpms.
THE BLUE BOMBER!
87 ford f-350 cab-chassis dually. 2wd, 6.9, 3 speed C-6. 3 leaf helper springs, 11,000 gvwr, pintle/ball hitch, 6 pin round trailer connector (unhooked currently). Rear generic truck stop lights. Twin I beam front end with coil springs. Plow lights and switch to go from headlights to plow lights. 8.5 foot meyer diamond plow with central hydrolics. 8 foot rugby dump bed. 167,000 miles and still strong.
WhiteGardens is offline
Old 08-22-2008, 06:27 PM   #3 (permalink)
Hi- I drive my 4 speed F-250 IDI at 65-70 with the cruise on everytime I leave home with it nights and weekends (I commute with a company service truck). I live 20 miles from the city and have never had a problem. For most city driving I skip 1st gear. I have been doing this for 7 years and have yet to have a problem. Hope this helps, now go get the truck!!
84 Diesel Lover is offline
Old 08-22-2008, 11:09 PM   #4 (permalink)
arthurgoboom's Avatar
The engine RPM will be a bit high, but like Whitegardens said, it won't be as bad as those of us with the C-6. They're both a 1:1 high gear (the C6 and the 4 speed), but the 4-speed has no torque converter to slip, so your cruise RPM will be a couple hundred lower. Mine is about 2450 @ 60 mph with 3.55 rear end ratio. Ask the seller what rear end ratio it has. If it's a 3.55 great, if not, it will turn even more RPMs. FYI Summit Racing and others have 3.55 rear gear sets available new, they're under $200.
The engine won't hurt itself due to RPM, the pump has a governor inside that will limit the engine speed to 3300 rpm.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 08-22-2008, 11:24 PM   #5 (permalink)
big99diesel's Avatar
I Have A 86 Lifted With 39.5" Tires 60mph Under 2000 Rpm And 4.10 Gears
big99diesel is offline
