The last couple days my truck has been running weird. The engine has been surging randomly while I am driving. Also the engine will start running rough after I start it, especially if it has just been run a few minutes prior. The engine has also started to run rough at a normal idle several times.
Just a little under 2 years ago I bought a return line kit and installed that. I do not see any visible signs of fuel by any of the injector caps. Also, I have a racor fuel/water separator and I do not see any fuel leakage elsewhere in the system. I also replaced the lift pump less than a year ago.
Before I installed the current return line kit, I was having problem with rough idle, but it would clear up after a 30 sec or so of running. This is the first time I have had the engine run like this after driving for a bit. Does this seem like maybe I need a new return line kit again, or could there be something else that I am missing?
1986 F250 Reg Cab 2wd 6.9l. 76k miles with early Banks turbo.
Just wondering if anyone has any input on my problem? I am thinking that I will just plan on purchasing another return line kit and go from there. My biggest concern has been the engine surging and rough idle after it has been running for a few minutes. I never had that happen before I put in the current return line kit. Before I installed the current kit, I was only having problems with rough idle and stalling right after I started the engine.
I wouldn't concentrate on the return lines, but rather check all potential sources of air intrusion. Fuel heater O-rings, WIF sensor, return lines & caps, etc. You might save yourself the hassle of doing return lines. Or you may find that the return lines AND something else are letting air in.
1990 Jeep Wrangler Sahara, 4.2l, 5-speed, Dana 30/35 w/3.07s (for now!), 33x10.5x15 BFG Mud-Terrain KM2s on 4" Rough Country springs. Engine being rebuilt after an awesome afternoon in the mud LOL
Other than leaking return lines should have no effect on a running engine. I would first check for leaks on suction( supply side) to include the tank pickup.
I had almost the same problem and I found I had #4 cylinder going dead. I found I had a injector stop working on #4 cylinder. So I ordered all new injectors and installed em and it went away.
"Nitrous is like hot girl with with STD's. You know you wanna hit it, but your afraid of the consequences."
66 Ford F100 - Project SickUp
85 Ford F-350 Crew cab Dually - Project Bagged on Semi'z
If you still have the factory water separator on the firewall, the drains are a known issue. Clamp a bolt in the rubber drain line, and see if that helps.
