tighten leaking fuel lines? - Diesel Forum - TheDieselStop.com
Old 11-25-2012, 02:20 PM   #1 (permalink)
I found that there is a leak on the fuel line going from the IP to #1 injector, at the connection to the IP. Is there a way to tighten the one fuel line without pulling the entire IP?
Darryl Elkins - 1985 E350 Conversion/Cargo van...6.9l stock 174k miles, Fitch fuel catalyst in tanks, C-6 auto, 3.54 gears.
Darryl97420 is offline   Reply With Quote
Old 11-25-2012, 04:47 PM   #2 (permalink)
chuckster57's Avatar
You may be able to get to the fitting with a crows foot flare. If not then just remove the steel lines on that side of the IP, starting at the top. Mark which injector it goes to and then just reverse the order to put them back on.
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline   Reply With Quote
Old 11-25-2012, 08:54 PM   #3 (permalink)
That sounds too simple! Considering I am replacing the fuel return lines and need to loosen things up, I will give it a try tomorrow morning.
Thank you,
Darryl
