tranny shifts hard - Diesel Forum - TheDieselStop.com
Old 11-28-2005, 11:29 PM   #1 (permalink)
h2odrx's Avatar
tranny shifts hard
is there a way to adj the tranny? or a fix for hard shifts? it revs high then shifts hard. help! [img]/ubbthreads/images/graemlins/confused.gif[/img]
Remember, we aren't eating this stuff, we're turning it into diesel fuel. Your truck only cares about viscosity, acidity, and BTUs. Nothing else. -unknown?
NC State law defines biodiesel as ''any fuel or mixture of fuels derived in whole or in part from agricultural products or animal fats or wastes from these products or fats.''
Exemptions from the excise tax
h2odrx is offline
Old 11-28-2005, 11:34 PM   #2 (permalink)
Seafarer12's Avatar
Re: tranny shifts hard
I assume you have a C6?
Massey 65
Seafarer12 is offline
Old 11-28-2005, 11:36 PM   #3 (permalink)
h2odrx's Avatar
I think so, it is a 3spd, i guess i forgot that, the tag in the door i could not read in the dark?
h2odrx is offline
Old 11-29-2005, 07:24 AM   #4 (permalink)
You may want to do a vacuum test first before you start adjusting anything. Are your brakes working ok?
Check Pete's Gallery for the test and some other goodies.
Has steered lots of folks in the right direction.
Rick
86 F250 N/A 4WD w/HomeGrown Propane, Poly Spring/Body Bushings, PushButton GP Controller, 3.55L rear, Goodyear WorkHorse II XTRA Boots, 248k miles, Rotella 5-40W Synthetic
Rick_Hipp is offline
Old 11-30-2005, 12:26 PM   #5 (permalink)
I too have a little bit of hard shifting on my '86 E-350 6.9 C-6. Pete's gallery gives a test for the vacuum pump but I didn't see anything about adjusting the throttle pressure sensor on the throttle linkage. Can someone tell me where to find that information?
Jim
1986 E350 6.9 based 27' MH. Weights 15,000# ready to travel. Hypermax conventional turbo. All exhaust to turbo pipes wrapped with 2" Thermotec pipe insulation. Turbo hot side wrapped with ¾" thick 2000° pipe wrap blanket material. Cold side wrapped with Foam sound deadening material. Turbo is silent! Hypermax hood inlet cool air intake system. Down pipe oulet to 3" then split to 3" dual exhaust exit behind rear tires. 3" in-out X 36"long round Walker mufflers. Ziggster40 design based propane injection. Gear Vendors Overdrive. 235/85X16 tires. Isspro EV pyrometer. Isspro 0-15 psi manifold pressure gauge. TCI C-6 deep finned aluminum trans pan. EV trans temp gauge. 10 3/4" brake booster from '93 E-350. Towing a '87 Suzuki Samurai Tintop
jauguston is offline
Old 11-30-2005, 01:50 PM   #6 (permalink)
Sent you a PM.
Rick
Old 11-30-2005, 04:31 PM   #7 (permalink)
h2odrx's Avatar
i found a spring unhooked on the throttle link not sure what it does but i put it back. if the thing was rebuilt wrong would this cause it to do this? about vacuum would a loose belt cause bad vacuum?
h2odrx is offline
Old 11-30-2005, 05:29 PM   #8 (permalink)
A loose belt could cause low vacuum and low vacuum=hard shifts so it's a possibility. Was the spring holding up the downshift rod ? The downshift rod has enough weight to hold the lever on the trans down---hence the reason for the spring.
1977-F250 SUPERCAB,4WD.,6.9,C-6,Banks Turbo
77f250 is offline
Old 12-01-2005, 08:43 PM   #9 (permalink)
h2odrx's Avatar
i was looking at those pics of the 7.3 head repair and i see why the trans shifts hard the downshift rod is missing? [img]/ubbthreads/images/graemlins/eek.gif[/img]
h2odrx is offline
